Johnnie Levin ZR 2008
johnnieboi
post-10034-0-25422300-1289213125_thumb.j post-10034-0-46112900-1289213140_thumb.j post-10034-0-08969200-1299680529_thumb.j post-10034-0-28051800-1299680548_thumb.j
[ZRE152] Toyota Corolla Levin ZR 2008 Graphite 6spd manual Hatchback
Current Mods:
Engine:
WeaponR stainless steel 4-2-1 headers (304grade)
TRD High Performance sports muffler Version. S [axelback]
Gearbox:
Solid shifter cable bushings
Suspension/Handling:
King springs lows Lowered 35mm front and 50mm rear (reset springs)
C-ONE Front Tower Strut Brace
Cusco Rear sway bar 16mm
Cusco lower arm bar chassis brace
Wheels&Tyres:
Enkei Evolution IX rims 17x8 +38Offset (Powdercoated Black)
Toyo T1Sport fronts and T1R rear 225/45/17 tyres
Exterior:
TTE Front Lip
Debadged
Removed Rear OEM mudflaps
Toyota Genuine Netz badge (Front) Flat black
Toyota Genuine Short stubby antenna
Toyota Genuine Slimline weathershields
Matte Black Rear Toyota Badge
35% Darkest legal tint - Tint Professor
Interior:
Toyota Genuine Boot liner
Razo 340R gear knob (Black)
Fire extinguisher with custom bracket (mounted passenger footwell)
Miscellaneous:
Phillips Crystal Vision 4300k parkers
Phillips Crystal Vision 4300k foggies
Osram Diadem indicators
Next on the list to do:
1. 60,xxxkms service, flush engine oil with Nulon engine flush, drop and replace engine oil (Castrol Edge Titanium 5W-40), change oil filter Baldwin B22, change air filter (Toyota genuine). Top up coolant (Toyota genuine)
2. Drop and change transmission fluid to Nulon Smooth Performance SAE75W GL-4, add Nulon G70 additive to new fluid
3. Flush brake lines, new brake fluid and replace stock brake pads finally. (Possibly Bendix)
Future Mods:
Black side mirror covers - Pending
Custom catback exhaust 2" piping upgrade (304grade SS)
XForce MP02(304grade) 2" inlet hi-flow muffler
Catco Hi-flow cat
Blitz Advanced Air core-type SUS Power Air Cleaner SRI
Pedders Sports Ryder Extreme XA Adjustable Coilovers w/ rear damper adjuster stalks
Pedders Front camber bolts
TRD Front Garnish (black) - Pending
RDA Slotted rotors front and rear
TRD Front and Rear brake pad set
Goodridge braided brake lines
EXEDY heavy duty clutch
PIAA 6000K LED Parkers
PIAA 3000K Foglights
TOMs Racing front mounting brace
  • Replies 265
  • Created
  • Last Reply
Top Posters In This Topic
Nice work Johnny!! Good to see that you're doing things, opposed to it still being stock last year.. hehe ;)
Awesome list of future mods too, similar to mine :P
Keep it up. Come out next time. :)
Peter.
Edited by dwee.
Just installed Phillips Crystal vision 4.3k foggies and parker globes. Much whiter brighter tone. No more stock amber hue. love it!
Thanks to tomee for the spare set!
  • 4 weeks later...
Just installed Injen cold air intake today with shinobi and dwee. All the installs went great. A bit tricky with the silicone piping but fitting was pretty straight forward. Improvement at mid range with torque from about 3.5/4k all the way to 6k rpm redline. Sounds great. Dresses engine bay nicely. Take some photos wen i can.
(Poor tomees zre engine light just came on, hope it turns out okay and mine doesnt come on.. :(
After so much drama with the CEL check engine light after the Injen CAI install.. i think its okay now. Installed injen hydroshield and went from pouring 91 to 98RON BP Ultimate fuel. Did ok after the hard run on the mountain from the meet. If it still proves to be a problem then gunna take it to performance workshop to get it dyno'd and tuned.
Next mod. TTE Front lip, taking it off tomees hands. Then still deciding on either rear reset or king springs superlow rears
Car's coming along well Johnnie :D :clap: Maybe go the superlows? From what I have read/heard sounds like that will give you more of the drop you're after.
Hope that stuff works out after the CAI install as well :) And the TRD lip will look hawt :D :D :D
  • 4 weeks later...
UPDATE: Side mirror fixed. Replaced new mirror cover and mount was aligned. Panel shop guy did it all in 20mins, for free too! :yahoo:
Next; TTE front lip from shinobi - gonna keep it black to stay with grey/black 2tone theme.
C-One Front strut brace
Replaced scratched front left rim
Blue nuts for wheels eg. work, BC, JDM
Ferodo brake pads front (maybe rear)
suspension is still pending.. possibly BC coilovers like Dwee. one day
Maybe thats it for this year. gota save for end of year trip overseas to asia. we'll see
Put stockies back on to track at Winton tomorrow with Duy. Drove 30mtrs out of cousins place, rear right rotor grinding and squeaky.. started grinding a bit into my rotor. Not the whole way around.. just one section.. no idea why. Gonna take it off later and check. hope its something small.. i pray it is. otherwise gg for tracking tomorow :( :( :(
Stock wheels on. All good. Took spacers out and stock wheels went on perfectly. Stupid rim spacers! Now for wheel alignment. Rear right rotor needs to be machined.
Thinking of selling rims.. and then
17" Kappas painted matt black with Federal 595 215/45/17 tyres :D
you'll noticed those are plastic hub rings essential for use on after market rims as they don't quite fit over the hub. What that would mean is that your wheel studs (where your wheel nuts go over or whatever they are called) will be supporting your wheel and that's a big no no......
sory guan.. dont quite get it? so for my rim setup.. shouldnt really have that plastic hub ring? not good? might leave stockies on for a bit. still deciding what to do
      Current Oil Specials
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    6. 11
      300 series turbo issues
      Any 2L motors for sale?
      Proud Owner of Toyota Crown
