i changed my exhaust not to long ago (canon)
was jus wondering does neone get this rattle
its at about 2,900 - 3,000 rpm
neone know how to fix
much appriciated
the place that fitted the exhaust has stuff up buy the sounds of things, that rattle is the exhasut hitting the heat shield, this means that when the cannon was fitted it was fitted off center where it goes past the heat sheilds and it touches from time to time and thats what the rattle is
i can vouch for dat my friend :P
take the exhaust off ...you;ll see where it is knokin on the zaust then use a hammer and panel beating dollie. apply hard hits liberaly untull you have desired effect :)
Had to do this with CES as my resinator was slightly longer than silvas
How about a rattle when i take off slowly with my stock exhaust..? is that considered as normal?
:o
much appriciated
Maybe it's rattling cause it's a milo tin.... :D
Did you add that one to your mods page :P
:o
Nope - I'd be looking into that one :)
:o
hehe take it to the dealer :P
as for rattles does anyone actually check where its coming from?
maybe its just the rubber mounts that's loose or something's loose. might be an easy fix. if not. take it back where you got it and get them to fix it. fixing it yourself and something goes wrong might void warranty (most places try blaming it on that.)
:o
:D Use a little more throttle on take off when easing the clutch out
ahaha, yes the good ol BOV from header joint, should ask rob about the person on the street, his face reaction was classic
  • 17 years later...
I have just had a custom exhaust fitted as well, is the noise more like a vibration??
Especially when you are talking off in 1st,2nd gear??
I'm having a similar problem the exhaust was fitted about 8months ago.
  • 1 year later...
much appriciated
Yes and it's a painful thing
      Tyre Sale Specials
    4. 10
      Remote start
    9. 10
    10. 10
