Help
Amaro
Silly question I tried searching but this time no luck!
Basically got the head unit off eBay for my aurion installing sound system and don't know were the hell a connection is for the remote wire from monoblock :o ?
If there is a post already could someone point me in the right direction :)
Your amplifier usually has the remote trigger terminal located next to it's power input terminals. You can't really miss it.
If you are referring to the head unit wiring and which wire is for the remote trigger, it is usually the dark blue wire with the white stripe on it. That's the standard.
And if you can't find it or for some reason your headunit doesn't have a remote trigger output, just tap into the ignition-switched +12v power line to the headunit (the red wire)
    2. 4
    3. 0
      Has anyone found 200 Series Rear Screen Delete Cover in AUS
    4. 11
    5. 1
      2007 - floor mats
    6. 1
    7. 0
      2002 Hilux Engine Replacement
    8. 3
      Engine conversion
      Po299
    10. 0
      Boot Dimensions?
