Oil Filler cap
Rear Tail lights - LED or normal bulbs
Does anyone know if the rear taillights are LED or normal Bulbs? The brake lights dont appear to be working so i thought id check first before pulling it out. -
P0303, rough idle, check VSC message.
Thanks. I'm counting on the code being correct. 🤞 No apparent surging, just rough idle. It feels ok at a persistent 60kph but the engine warning light starts to flash at any acceleration thereafter. Slow and steady feels ok. It looks like I will have some time after all...so I'll get some gaskets/seals/parts and have a go. This video seems pretty good. https://youtu.be/ING-RK7NJ-c?si=S7i8rLRlDaKEp94i This one too... -
5
Poor performance, surging can also be related to dirty/clogged fuel filter I forget the maintenance schedule for these, but in any car it's more of a 'do when you need to' routine -
6
Tarago Radio/Head Unit SD Card
We're experiencing the same thing. Can you please send my way too. [email protected] Cheers! -
17
17
CH-R sudden engine failure
I fought with Toyota for the last 6 months on this issue. I attempted to reject my vehicle due to safety and Toyota began to investigate my request. During this time they offered me a new engine. I asked if a new engine would affect my rejection claim and they said no. After this they rejected my claim and I supposedly have no further argument as essentially the new engine was a satisfactory response to a major failure under consumer rights. After months Toyota still won't tell me what damage there was that required my engine to be replaced. Other than confirming carbon build up on the manifold months prior to engine replacement. They will not give me any information. Everyone I speak to tells me they cannot comment. I never wanted the repair because the problem is so common I don't feel the repair was enough to prevent a reoccurrence. I even asked for confirmation that a repair would be enough to prevent further occurrence and that the vehicle was safe and would no longer lose power on acceleration. They responded to this with a letter stating Toyota could not provide the information or guarantees I had requested. -
Finally found all Tarago's 6 speakers - 2 in roof lining
I had a look on my 2019 Tarago but couldn't find it in the roof lining. They must have removed it on the 2019 model -
5
Haha yes. Thanks for the reply. If it was that simple it'd be done already. Getting all the other stuff off to gain access will take some time for me. Unsure if I'll have a crack at this as a bit time poor...I think I'll give the mechanics a call tomorrow. It had a recent service...hopefully they can take it in asap. (daughters car). -
P0356 - Ignition Coil 'F' Primary Control Circuit/Open
Last weekend, engine on startup was running rough. OBD2 Scan revealed a P0354 error code. Cause proved to be a loose connector to the ignition coil on cylinder 4. Quite some time ago, I had previously viewed a YouTube video about using a zip tie as a repair instead of replacing the connector with a broken clip. As an immediate alternative, I used a small shrink wrap to provide a more secure connection. Have to find a suitable zip tie as per the following YouTube video.- 1
