Hey I've tried to have a look to see if this was anywhere else but nothing came up.
I was thinking of changing the reflectors to these
http://www.ebay.com.au/itm/Aurion-06-Rear-Bumper-Light-Reflector-LED-RED-TOYOTA-/360372025733?pt=AU_Car_Parts_Accessories&hash=item53e7d8b985
any suggestions or has anyone tried this already?
Steven helped me installed mine when i bought it about 1.5 years ago.. there are a couple of us with that installed.. we did a group buy back then from Bangkok.
Oooo these look allright :D
I wouldn't mind seeing a picture or small vid showing them installed and working, as im not to sure how it would look at first glance with already having the 4 taillight LED circles and also the spoiler light :\
but without that i may buy some in the future :P
ive had them in about the same time as Ingres. love them! have a video on my phone, and will see if i can upload it..
Awesome :D i spose if you like em i probably will !
Seems to be a general yes then :D
The installation must be pretty simple.
Which way do you go to change them?
Up from the bottom or from the boot?
I've had a quick look under the car but with no avail. (didn't help I was lying on rocks and it was getting dark)
I'm gunna now assume that you pull them straight out and drill a hole for the wires to go into the car...?
It's been awhile now, but I actually removed the rear bumper to get easy access. The reflectors come outwards from the car but they have a screw holding them in behind the bumper.
For wiring I used an existing grommit that leads into the boot cavity and spliced into the factory harness for the tail lights.
Fairly straightforward but a bit of mucking around involved.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
