My Corolla sportivo
456LFT
Hey dave
I have done the following so far:
- Painted rocker cover
- Adjust clutch
- Changed gearbox oil
- Weather shields
- TRD HD Rear sway bar
- TRD Front strut brace
- I have brought my excedy HD clutch which ill be doing this weekend, also adding nylon G70 additive
- Have my simota CAI on order
- Have TRD Rear strut brace on order
- Next mods are probley coilovers asap posibily Tein , extended push rod , hondata inlet manifold gasket and a few other little bits and pieces for the time being
cheers mate
haha yeah true screw that then cheers man
- what coilover do u guys reccomend, have on ur car ect cause im still tosing up between afew ?
Depends on what you want out of your car?
Soemthing nice a comfy for the street, go the Tein (or Koni struts and King springs). Something stiffer for the track, go the Cusco. Or if you want a different brand the spring rates for those are still apllicable for the direction you want to head in.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
