Can anybody help me to figure out what is the correct tyre pressure for Toyota Yaris ? Is it the same for front and back both ?
check the side of your drivers door, it should indicate it there,
Same for both back and front and it it is for tyre size 175/65R14 82T ---- & 185/60R15 84H
220 (2.2. 32 )
I copied this from the manual
  • 3 months later...
You need to put about 36-40PSI front and rear despite what the manual or tyre pressure chart says as this is standard for Japanese roads (where the car is made) where the roads are much smoother.
:spiteful:
  • 5 months later...
I just changed my tyres in Kmart Auto they put in 40psi.
You can not get even wear if you just put in the manual recomm.
uneven wear can be caused by many things, not just incorrect tyre pressure. there is camber, toe, wheel allignment to name a few
  • 2 months later...
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
