Sportivo dyno tune
Hey guys,
i was thinking about putting my sportivo on the dyno for a tune but i think i might have some problems,
i heard with the sportivo's they have some problems with the gear boxes, i was wondering if i put it on the tune would it do damage to the gearbox like gears crunching ?
and what kind of tune would be best for the most proformence for the sportivo
Do you have a piggyback or a stand alone ECU? If not, then there is nothing to tune.
As for theg earbox issues. The crunch only occurs when changing gears. If it doesn't do it on the street, then it won't do it on the dyno. The gearbox will be fine unless you are making 250+kW, which I have a feeling it doesn't.
      Remote engine start from key fob 2014/15/16/17
    2. 43
      Upgrading 2010 Aurion ATX Headlights
      Seeking Head stud socket for 1.5l Yaris engine - supplier?
      brake accumalator 1991 soarer
      Hi -Ace Fuel Consumption
      Remote not working properly
      Head Unit Replacement
    9. 1
      New Member '93 Corolla CSI -Tim
      RARE TOYOTA V12 CENTURY
