What is this switch/sensor
looks light your headlight adjustment, it adjusts your headlight beam levels, so when there is weight in the rear your headlights will aim down instead of it aiming up
Your location says non-au. I haven't seen that on the Sportivos here, nor have I seen those rear brake calipers on a sportivo (assuming I have orientated myself correctly). Euro corolla? Can't help with what it is though.
Now that would be cool, but I dont see how that would work?
Sorry thats just a picture off the internet, but my corolla has the exact same thing.
Kenshin X is right I have a JDM corolla in NZ
some cars also have a similar sensor for brake bias for the abs to know how much weight is in the rear, and also some vehicles have a ride sensor similar for pushbutton suspension(ie sport or comfort) a lot of older mazdas had this....
I wonder if I should adjust this then. As the car has been lowered.
Guess I would have to confirm for sure.
Thanks for all your responses
ABS and brake distribution is happening at the limit of traction so yes I think it needs to be a finly tuned system,
What if the car though there was more weight in the back and applied the rear breaks harder and caused a spin mid corner? Infact I think the back end of these cars lets go pretty easy for a FWD.
what does everyone else think?
That looks a lot like a Load Sensing Valve, they are commonly used in utes and light to heavy trucks to increase braking to the rear wheels when there is additional load in the rear. However, when there is no load, the braking force is not required to be as strong so the valve reduces the braking pressure to the rears and prevent spinning. Due to the car being lowered and the axle being closer to the chassis, the valve thinks there is a greater load and would be applying more pressure.
I would suggest you have it professionally adjusted as they are often very sensitive and if you mess it up it could have serious consequences.
Thanks Dan for the helpful comment :mellow:
Sometime it feels like the car breaks too hard on the rear, I can think of two instances where ive been fooling around and touched the breaks mid turn and had the back let go been fine controling it tho, just makes me wonder.
This makes me think even lowering springs with a difrent spring rate would also throw out the calibration hmmmm :g:
Well after some research it appears to be a height control sensor.
http://www.toyodiy.c...QF_8401.15.html
Thank you so much, such a good resource
so it is a:
89407 SENSOR SUB-ASSY, HEIGHT CONTROL, REAR RH
So I guess now it could be for two possible things:
- headlight leveling
or
- Brake Bias / electronic brake force distribution (if so it may be very important to correct it the nearly 2" the car has been lowered in the rear)
What do you guys think? :g:
cheers for all the great work and help so far.
    2. 3
      Toyota Landcruiser problems
    4. 13
      300 series turbo issues
    5. 55
      Stout Owners
    6. 13
    7. 8
    8. 55
      Stout Owners
    9. 2
      New Member
