Looking at the standard grounding fitted to the Corolla, it's quite inadequate to say the least.
What grounding kit's do you recommend?
By the way I don't have any sort of upgraded ICE, just wanting better voltage for lights etc
Not wanting a voltage stabiliser, just a grounding kit.
DId you try Danz's DIY solution?
search for it
Yes you do not need the voltage stabilizer if you do not have audio gear or gadgets. If you just wnat to change the cables, upgrade them to size 4awg. It really does makes the car smoother, honest.
Try it my way, the same way as with my audio install, and you're set to go man. I did that for my DIY grounding.
      Remote start
    6. 10
    7. 10
      Turboed Corolla Overbuilt?
    9. 3
    10. 3
