TIMING CHAIN/BELT 2004 CAMRY ALTEVA 4 CYLINDER
sprint
I have just bought [privately] a toyota 2004 Camry Alteva 4 cylinder Sedan Auto transmission
Do these engines have a timing belt or a timing chain?
If a belt or a chain - when [klms] do they need replacing?
What does it normally cost to have replaced by a local mechanic?
Speedy
$250 cash for my V6 Camry timing belt change( I supplied all the parts no water pump !), 4 cyc should be cheaper i think.
The 2az-fe does not run a timing belt and a timing chain change is usually more expensive.
Also, you can't compare cash payments.
    2. 83
    3. 26
    4. 2
    5. 2
      Head Unit with Apple CarPlay
    6. 3
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
    10. 1
