As u need to take off the box. Might as well change the clutch too while ur at it.
I would change the clutch first, and ssee if that fixes it, had a similar issue in another car, but would be gone after the car warms up a little
If you are going to change out the clutch would be mad not to change the bearings at the same time. And yeah I would go with it being Spigot or throwout bearing as well
you been under water recently. The Don is right it is either the Spigot bearing or front gearbox bearing. They have a habit of shtting themselves once the bell housing fills up with water if you get stuck in a creek for a little too long :P
haha sure! i reckon i can beat ur hilux across the creek anyday. i have "lift" :P
      Remote start
    2. 1
    3. 0
    4. 9
      Android auto
    5. 9
      Android auto
    6. 1
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
