FOGLIGHT REMOVAL
BanGn
Justin... it along way for them to come from Melbourne...
it's pretty easy
step 1 - locate the panel in front of the wheel arch underneath the car
step 2 - remove the blister plug and 2 screw that secure it in place
step 3 - open the panel (may need to shimmy it out a bit but don't worry, it's hard to break
step 4 - unplug the red plug on the top of the light fitting
step 5 - locate the press locks on the side of the light fitting to the inside of the car (should be 2)
step 6 - use you fingers (or is that fails some pinchers or even a flat scredriver) for pinch the press locks and push the light fitting out
step 7 - stand back and marvel at the ease in which these things are removed and have a beer
step 8 - replace the undertray panel and screw back in place and replace press stud.
oh yeah haha i didint realise
hey the plug that plugs into the globe itself
is it a loose wire
i mena can i relcate the light from the front of the bumper
to say the back of where the small box is where the fog light is in
or do i need to explain myself more LOL
does anyone know how much a new bulb for a fog light costs from toyota? because its not just a globe, the globe is attached the the water proofing plug in the back, so that we have to spend more money at toyota.
it's pretty easy
nah , my way u just go under the car to do it.
  • 2 years later...
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
