ive heard ford rims fit but from whats series etc i want 17" but going for ford would be alot cheaper
Needs to be 5x114.3 PCD, and depending on the width somewhere in the +35 to +45 offset range (don't quote me on those offets though). As far as Ford rims are concerned, you'd be looking at Falcons from AU onwards (and the Territory too, obviously), but make sure you check widths and offsets as you can probably fit a much bigger wheel under an XR8 than an SXV10 Camry.
There are tonnes more manufacturers out there apart from Ford that have 5x114.3 wheels though, so don't limit yourself to just looking at Falcons...
Yeah a
N
+1 Yeah id be looking at other toyota models possibly Kluger or if not some jap wheels perhaps.
17x7, +45 just fits inside the front guards. You may be able to get away with a 7.5" rim, but will run into issues with 8" wheels.
all good just picked up a nice set of low profile 17's and with 90% rubber for 150 im happy as f***
Good buying for you. So what wheels did you choose ?
ended up getting some ROH look alike penta's they suit well the only issue with em ive noticed is one of the tyres has a very slight egg in the wall which will be change this week for safety reason but makes a huge diff to handling , no all i need is some low on it to get rid of that ridiculous amount of roll on it
Posted (edited)
only paid 150 for em too which im stoked about
Edited by 975s-fe
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
