That's a dual-cab tub, much shorter than the single-cab. It's also an 8th-gen Hilux tub, the OP has a 7th-gen @rckly Redbook seems to show the single-cab tub was available in the 2WD low-rider spec, for the high-rider/4WD it came as king-cab or dual cab only (cab-chassis available for all shapes and sizes) -
Toyota Landcruiser problems
Hi This is not so much to the forum but to Toyota who i cannot contact!! Purchased new 300 Landcruiser ($120k) & generally happy with the drive but frustrated with fixing problems. bonnet need restuffing took me 5 Toyota dealerships & a lot time i cannot afford for a 3 day job afer it had been booked into Heidelberg & on collection did not perform the stuffing to stock it shaking & reflecting strong sun light into drivers eyes when vehicle was clean. when i collected vehicle from overnight service (2 days) after 2nd visit with some booking confusion they told me they need vehicle for 3 days just prior to me driving from Melbourne to Flinders rangers SA again very costly in time to me because a bolt had fallen out of turbo charger (20k klm). i have had a list if issues none of the 5 Toyota dealerships visited can resolve: no guests can close the rear hatch because you need to slam it & most do not have the strength even if they new what to do - seal has been replaced. i have never been able to understand logic of why no rear hatch release was included in vehicle, 1st vehicle i have owned without boot release? no location for key apart from centre console where key is lost amongst so many items unable to reverse any trailer, boat or horse float as vehicle brakes & locks up which is dangerous to horses being thrown & reversing into drive with traffic on a busy road - every possible idea has been suggested again very expensive on my time but no one can resolve! Unable to get google maps or music without plugging cord into phone - very aged technology but safari same vehicle does not need cord!! do not understand this logic other than justifying another $20k Radio or music must be reloaded after each phone call or restarting vehicle - some 6-8 buttons to reload music - very frustrating. AM 3AW is muffled & very poor quality (not my hearing). Alarm of beeping drivers door cannot be turned off - i do not need vehicle to alarm warning me of drivers door open as i am the one who purposely have left door open - very frustrating & no need for alarm beeping, cannot turn this off!! Ordered dark interior but got light interior ?? which i accepted on the condition the carpet was not light beige, guess what it was. Why would a country farm 4 wheel drive have white carpet? Toyota what are you thinking? i have a black cattle working dog so my rear interior is trashed & the fabric entraps dog hair unlike a good quality wool carpet, poor quality synthetic which is not serviceable like previous BMW quality. i would love Toyota direct (not dealerships / agents who are not trained) to help me resolve direct. Direct contact with Toyota not possible, customer service from dealerships disappointing based on cost of vehicle, i believe i am a very reasonable person. -
7
selling car
Spamhuman* Just wanted to see if google would crawl the link -
5
Toyota Corolla 2012 ZRE152 4 speed automatic issue
Hi mate, did you solve the issue? -
Fuel Filter - Change or not
This is the conundrum: 200 series Landcruiser diesel. As the fuel filter get dirtier, in theory it is filtering more as it is becoming somewhat restrictive. As long as the fuel pressure remains the same on the other side, should you change the filter. I know of owners who change their fuel each time they change engine oil. This is not the same as an air filter which as it get dirty it restrict the air flow. Or do you simply change the filter because it's 'the right thing to do'? -
2013 cruiser gxl ute
The brake lights come on at times when the ignition is off ,I've changed the brake sensor above the pedal and also while driving at times I lose power -
I bought my 2006 ATX Aurion back in 2015/2016 with 160,000 KMs on the odometer. 8 years and 100,000+ KMs later, still going strong. I do a lot of preventative maintenance with regular engine oil changes. Transmission fluid has been changed and also the coolant. In that time period, I have replaced the water pump, alternator and both front and rear struts/shock absorbers. In hindsight, I have replaced brake pads much sooner than needed. Overall, future maintenance should not be expensive.- 1
Hi Reece, I've been trying to reply to this post, but for some reason the site wouldn't let me. On one of my morning walks, with my dogs, there is a Hi Lux tub sitting on the nature strip. I know nothing about it, except that I think the owner could well sell it, but hasn't. I will attach a photo for you, and if you are interested I will email you the address, if you PM me with it. Note that it is in Geelong, Victoria, maybe a good reason to visit. . Herb -
Fitting on the headlight bulb appears to be the usual twist to release and lock. Definitely do not try to brute force the removal because you will definitely break something like the headlight housing. Suggest that you use some WD-40 and have a real good look at the existing bulb using a mirror and a good light source. Then have a few wiggles attempts to loosen the existing bulb so it can then be removed. If this does not work, then time to be smart and not stubborn. Far better to pay a $15 fitting fee than the exorbitant cost to replace a damaged headlight assembly.- 1
