Camry 2015 Dual Exchaust
Aussie Camry
Speaking  as a Toyota tech, 100% for looks only. If you go for an aftermarket system or remove some of the mufflers for the OEM system it may be a bit louder  (although I dunno why you'd  want that, it'd  just sound *******...)
I see Mr. Toyota shows different kw and nm specs for the base model Altise with single exhaust versus all the other variants with dual exhausts. Altise has 133KW & 231Nm where all the others have 135KW & 235NM. All models show the same fuel useage.  So yes performance will be increased but only a small amount. Only you can decide if the cost to add the second pipes / muffler/ brackets will be worth it.
Take it with a grain of salt.
If it is actually true, you will not notice this. These are flywhewl figures, so once you factor in the percentage of drivetrain loss and the extra weight from the extra muffler :tongue: you will gain nothing.
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
