2003 Camry clock and automatic gear shift light not working
JBirch
Hi all,
My 2003 Camry Altise clock, automatic gear shift lights and climate control lights don't turn on.
Now all that I have tried is checking the instrument panel fuses to see if any had blew out but they are all fine.
There has been a few times where they would all work fine but this only lasts until I turn the car is completely off.
The lights and clock haven't turned on for about a month now and was wondering if anyone had a solution to this?
Thanks!
Edited by JBirch
Yes I saw that although that just seems to be about the clock itself not including gear shift and climate control lights. Is it possible that the clock PCB also controls the lights as well?
I've searched around for a while but couldn't find a solution.
  • 3 years later...
My daughters 2005 Camry has/had the same issues.
Tried to fix the clock, videos available on-line to show how it's fixed, but I'm a klutz when it comes to electrical work.
Fixed the auto shifter light myself. There are a couple of videos around showing how to get to the bulb (T5 size A.K.A. grain of wheat bulb). They're available at all auto parts stores and larger servos. 2 to a pack. Be careful as you are removing various plastic bits to get to the bulbs. Not hard to do at all.
The bulbs in the climate controls I haven't fixed yet...same sized bulbs apparently.
I hope this helps.
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
