Hi Guys
emkay
Best to use the Search box on this Forum. You may be able to quickly locate the answer to your question. I also do Google searches for the 2GR-FE engine and U660E transmission. In the USA and other countries, the Aurion is a V6 Camry and a similar model for the drivetrain is the Lexus R250 [?].
Hopefully, your 2006 Aurion has been regularly serviced and you have the service history. What is the odometer reading? If it is more than 160,000km , seriously consider having the transmission serviced and a new transmission filter fitted. Also check the engine for oil sludge. If present, do an oil flush or 2, regularly replace the oil filter and use quality engine oils. Personally, I do this every 5,000km with mineral based oil. My research indicates that with synthetic oil, the change interval can be extended to 10,000km. Hope this helps with your servicing plan.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
