I poped out one of the front door curtesy lights out only to find that they are just blank ??? why would they do that  ??? does anyone know if the wiring and plug are there tucked away to be hooked up ?
Nope, no wiring. I have a 2014 SL & a 2015 SL  no courtesy lights supplied. I questioned Mr. Toyota and there is no satisfactory answer as to why there are none but, they did point out the red fitting does have a built in reflector to warn approaching traffic the door is open ! I intend to purchase some of the LED units from Ebay to fit in and wiring up to both my SL's.  I think the lack of working courtesy lighting may be a cost saving issue.
I will be doing the same I already brought a pair of LED Toyota Logo lights and will also have them wired just need to get the plugs with wires from a wrecked model that has them.
  • 10 months later...
The Aurion has these on all models, perhaps the wiring harness from the Aurion?
Toyota should do this. 50 cents **** for mass production.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
