Posted (edited)
Hi, my Corolla has had this vibration for a couple of months now, which is very annoying. It only happens once I get above 90 KM/h and gets worse the faster I go. At first I thought it was the front tires so I changed them and got them balanced, and it still persists. Had a slightly bad rear driver's side bearing and just thought the problems were related but that was not it neither as I changed it to. Any help would be appreciated.
Edited by Darry
wrong wording
Copied from the following URL https://repairpal.com/my-car-sterring-vibrates-in-high-speed-849
This could be many things, there is not one simple answer.
First thing is figure out if the vibration is wheel/rim based, or suspension based. The easiest thing to do would be to rotate your tires (front to back) one at a time, then take a highway drive. Tire/rim damage becomes far less pronounced when the wheel is in the rear. If the problem clears up, you know the problem is wheel/rim based, and which wheel it is as well. You either have a bad tire, a bent rim, or need your wheel balanced.
If the problem does not clear up, things get more complex. While you have your car jacked up, but your hands at 12 and 6 on the tire and rock back and forth. If the tire rocks, you need new wheel bearings asap.
If you car clicks when you make sharp turns, it is the CV joint, but you could still get a vibration from a bad joint before you hear clicks.
It could be a bent hub. A mechanic will have to do the hub or bearing job, as it requires special tools on your car. It's also expensive (several hundred).
Check the front wheel alignment.
From there on out, suspension components such as control arms and rods, or pehaps drive axles may be damaged. Your car may have previously been in an accident and time made the damage more pronounced.
