Upgrading 2010 Aurion ATX Headlights
Engine Cost for Sportvito SX6 2007
Another option is to buy another 40 series Aurion, and keep the wreck for spares. -
Passenger footwell wet ? roofracks?
I just bought a 2017 hilux dual cab ute. Got it home and noticed passenger side footwell damp. Lifted carpet and underlay is soaked. Called owner who denies it ever being wet but says he only installed the clamp.on roof racks 3 weeks ago. Says I should take them off as they must be the cause. Have done this and am trying to dry out the floors but are there other possible sources that I should check? Thanks -
I just bought a 2017 hilux dual cab ute. Got it home and noticed passenger side footwell damp. Ligeted carpet and underlay is soaked. Called owner who denies it ever being wet but says he only installed the clamp.on roof racks 3 weeks ago. Says I should take them off as they must be the cause. Have done this and am trying to dry out the floors but are there other possible sources that I should check? Thanks -
5
Camry Navigation System
2019 Camry Hybrid Navigation for Android. I just had a $180 software upgrade on my SL at my local Toyota dealer and now my Android phone google maps display and integrate with the cars system. I believe the upgrade to Android/google was done for the RAV4 due to customer pressure. You do need to physically connect via the USB port Prior to the upgrade I spent a lot of time trying to get it to work via Toyota Link and so on. As it turns out now, no other connection software or apps should be running. Just your Android phone and USB connection.- hybrid
- navigation
(and 1 more)
Tagged with:
N80 2015-2017 infotainment upgrade
I have just installed a interface behind my factory unit which is all plug and play I now have wireless or corded apple carplay and android auto wanted to share on here to make aware there is a option with out having to buy a whole new stereo all the functions work ie steering wheel controls and reverse camera and all the factory options in the stereo are retained also I am soo impressed I am now supplying worldwide -
Hello There
Will be starting to do body work and painting hzj 75. Will be looking for info. Removing panels, etc. Thanks -
Central locking
I have a land cruiser HDJ100R 2001. I have changed the remote batteries and tried to reprogram the system, the remote will lock the car but want unlock the car. Can unlock the drivers door with key but won't unlock any other doors. I can unlock the passengers side door with key but no other the key will lock the tail gate but won't unlock it. The remote will lock the car and you can hear it clicking to try to unlock. If anyone has any ideas what I can do to fix this problem. I rang around trying to see a local auto electrician. but they are busy till next week. Thanking You HDJTom -
Brake Rotors 2013 Toyota LC200
Used front and rear rotors to fit 2013 LC200. Front 340mm, rears 350mm. Travelled 90,000km. No lip, never machined. Rears 18mm thick, fronts 32mm thickPads are for reference to illustrate wear. You are welcome to take them with the rotors. Pickup from Beachmere, QLD
