Transmission wont work
Deyrick
Need some help with my 07 Trd aurion ..was a total idiot last night an did some reverse donuts(neva again karma I guess) now trans doesn't work it's like it's in neutral have breakdown service come out he put it on computer an came up speed sensor fault ..anybody know if that would be rite or have I done the trans(hope not love this car an my first of this kind) cheers all..an yes I did big stupid
I am not an automatic transmission specialist but I do know how to do internet searches.
Following URL indicates that the speed sensor can fail due to the transmission overheating.
https://maktrans.net/Dattchik-skorosti-AKPP-U660E-Toyota-Camry-06-up-RAV4-09-up-Avensis-09-15-Highlander-13-up-Avalon-07-up-Lexus-ES350-06-15-NX200-14-up-RX350-09-up-8941333030-B-U
Bad news is that this component is internal. It is most likely located near the valve body so hopefully can be accessed without having to remove the transmission.
If you have overheated the transmission then the ATF will also need to be replaced.
You will be poorer in $$$ from this experience. If you want to do stupid, then get yourself another car e.g. Ford Turbo XR6 then blow up the turbo [like my son].
Looks like best option is to put second hand trans in can get done from wreckers fitted for 1000 is that ok price trans has done less ks than my car also is trd trans same as normal aurion cheers
Oh Deyrick, Aurions aren't the right car for donuts mate. Sorry, but karma has bitten here. Who knows what kind of damage you've done to it. You could have also damaged the CVs too.
If you can get a transmission for 1k (that is if it is in fact broken), I'd jump on it cos they are usually around the 3-4k mark. Ashley you can correct me if I'm wrong.
Get yourself a proper, rear wheel drive and go to town, preferably in a controlled environment such as the drag strip or something.
We don't advocate dangerous driving here..
Good luck with it and let us know how you go.
Tony
My experience is that the Aurion is a great Highway cruiser. Able to run all day and when you need to overtake, there is plenty of power for a quick overtaking manouvre then back to leisurely cruising.
I know that I have a V6 with 200kw of power and have nothing to prove.
In my book, winning is all about getting safely from point A to B. Losing is a broken down or wrecked car. Prefer to leave that to the Holden and Ford boys playing with their toys. Also a low profile means no police attention and those involuntary offers to contribute to the Govt coffers.
I'm hearing you both it's not usually my type of thing just had a stupid moment an too top it of I'm in my mid 50s makes it worse apart from that in love with the aurion surprisingly so in fact.thanks for all the help ile update wen I've sorted the problem may get it back on a scan tool c what happens
You nailed it Ashley. My Aurion always gives me a sense of satifaction when I drive it, which is not that often as it's my wife's daily.
On the freeway runs it's a Boss car when you need to overtake. The power delivery is effortless and smooth. I  like to fly under the radar too.
For me, It's the perfect family car. Unpretentious, reliable, comfortable, smooth and best of all, It's fast when you need it to be.
Give her some TLC mate. She may forgive you someday lol..
Hope to hear back from you soon.
Take care and stay safe Deyrick.
I'm in Sydney, otherwise i could've helped you myself.
I invested in one recently so I can do all my cars.
Modern cars, it's become a necessity unfortunately. If I were you I'd look into buying one for yourself, that way you can avoid having to pay someone.
You can get decent ones for a couple hundred dollars. Shop around.
Just now, Deyrick said:
Thanks mate ile look into it kinda hopeing clearing the codes may help
No problem. I suspect though that just clearing codes wont fix a pre existing condition.
If there is a hardware issue then the code will keep getting thrown up.
You may be lucky enough to have someone near you who can hook up to your OBD II and see what's going on. It will be a good starting point.
Regards
Tony
3 hours ago, Deyrick said:
Got it scanned came up with code c1201 whould that stop trans from working
Does your car have "Check VSC System" on your instrument cluster ?
What about check engine light ?
Are there any warning lights indicating at all ?
C1201 code can be many things and not just one specific item. This is the problem with decoding. You will end up shot gunning the parts process an be nowhere close to fixing the issue.
For eg. http://c1201.enginetroublecode.com/toyota-aurion  This link talks about several things not even remotely related to your car and yet it discusses C1201.
My experience with electronic glitches is always check the wiring integrity. Check ALL the wiring plugs are mated correctly around the engine and I mean everything. get under the car too and take a look under there also. Check the wiring to the transmission. ( don't ask me where it all is, just take a look). Sometimes wiring can come apart or even moisture ingress and corrosion sets in.
Maybe your reverse donuts ( I'm just picturing this in my mind too,... so funny) has managed to shake part of the wiring loose from your hooliganism. If it's something controlling the transmission then it will make sense it feeling like it's in neutral. It may not be communicating.
Worse case. Take it to Toyota and have them scan it with their equipment.
    4. 14
      Hi from Wagga
    7. 2
    8. 2
    9. 2
      Engine oil dipstick reading
