Carolla ascent sport take off power / Revs drop
Hi all my first post, I have just bought a Carolla ascent sport 2014. 115000km , 6 speed manual. I have a driving school
and have noticed that at take off the revs drop off almost stalling. I am no stranger to manual as I teach manual in my driving school.
even on level road if i let clutch out slowly car shudders and i have to really keep revs up over 1.5, idle is just on 1. Once i get going its great after second there is instant power
and drives exceptionally well. checked one spark plug ngk platinum ? seems Ok?
any ideas how i can improve take off.
Ken
Just had a look at the photos of that spark plug. It could possibly be a non-genuine NGK spark plug. So I would be inclined to change the spark plugs, clean the MAF sensor and the throttle body.
thanks Ashley will definitely change plugs, by the way do you know if i have to put the rubber sleeve over the top of the plug?
see foto
thanks
Short answer is that I do not know.
However I suspect that the rubber sleeve is to keep dirt and oil out of the spark plug opening.
Best to put them onto the new spark plugs.
19 hours ago, kensteyn said:
Hi Kroeger, was hoping to avoid a massive cost at the moment. I will try the other suggestions. thanks
Sometimes it is unavoidable. But keep doing all you can before you take it to a professional. Cheers
see foto
thanks
Not seen these before. Are they present on each plug? Perhaps contact these guys to get some information on the ignition system https://au.toyotaownersclub.com/profile/45808-swan-ignition-coils/
that makes sense. the rubber was in there when i took coil out. the spark plug socket got stuck in the tube around the rubber which i pushed down. i had to put some wd40 and twisted and pulled for about 5 min before i could actually get the socket out. so it been in there from whenever, i have only had car  for week now. Thanks Mark
i will assume it does not belong there. Could not find a name, but person from swan ignition coils has been great with advice and info
If its part of the socket, it definitely doesn't belong on the plug when you replace them.
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
