Posted (edited)
What Laser Measure Tools Are Suitable For You As A Beginner
The importance of owning efficient and smart tools is equal to everyone, no matter if you are a beginner, DIY homeowner or a professional worker at some job site. Tools can just not make your work easy, it can also save valuable time as compared to the traditional methods. The same goes for measuring methods, now laser measure has made things way easier.
Today, we have come up with some of the models that are suitable for any beginner in terms of operating and providing accurate results.
✿✿✿ Further Reading:  Best bluetooth laser measure - Top laser measure for architects.
Best Laser Measuring Tools For Beginners Reviews
#1 - DBPower Digital Laser Measure:
This feature-loaded device is suitable for all the beginners and DIY homeowners out there who are looking for some simple tool to measure but with accurate results. This tool can help you in having the desired results.
Features:
❈DBPower digital laser measure is offering area, distance, length, continuous measurements, and volume. It can measure about 197ft of distance.
❈It has come up with a backlight that provides visibility to a user in low light conditions. It’s compact and portable in nature so you can put it in your pocket and travel anywhere.
❈It works on 3AAA batteries and by pressing the buttons, you can activate any of the functions of this digital laser measure without going through complications of operating.
#2 - Bosch Blaze Pro 165' Laser Distance Measure GLM165-40:
Bosch has always come up with powerful devices with long-range measurements, and it provides confidence to the professional user. Bosch GLM165-40 will help you in operating the device with just one button.
Features:
❈The accuracy of this laser measure is extreme and it’s a user-friendly device. It can measure distance about 165ft with accuracy and precision. It can store about 10 recent measurements in the memory.
❈It’s compact and portable to fix in any pocket and has come up with a backlit color display that allows users to read the numbers and settings on-screen in lowlight.
❈It has an auto square function, and this device is IP54 rated to protect internal delicate parts from rain, debris, and dust in rough conditions. This device is suitable for any kind of user.
#3 - Dewalt DW03050 Laser Distance Measure:
Dewalt is another premium brand that always comes up with reliable, durable, and smart digital devices to make a job easier and to provide accurate results. DW03050 laser distance measure is user-friendly and inexpensive as well.
Features:
❈Dewalt DW03050 laser distance measure can provide automatic area and volume calculations. It works on the Pythagoras theorem and measures indirect distance.
❈The memory unit of this device stores about 5 recent measurements. It also has a 2-line backlit display to help the user in reading the screen in low light.
❈It can measure the distance of about 165ft, and it’s also IP65 rated to protect the internal parts from dust, debris, and water. Environmental factors or rough conditions can’t damage this device.
☞☞☞ See It Here: Best laser measure - Complete laser tape measure reviews.
#4 - LEICA DISTO D2 Laser Distance Measure:
As a beginner, if you are looking for the kind of laser distance measure that can provide all the features from one platform, and it should be compact in design, then this is your right companion in any kind of work. Leica Disto D2 is a suitable device for almost any kind of user.
Features:
❈Leica Disto D2 laser distance measure can calculate about 330ft without any error, and it can also transfer your measurements to the phone, tablet, or any other device. This device has built-in Bluetooth.
❈The design of the device is compact and lightweight so you can keep it in a pocket and there will be no handling issues. It also has a flip-up bottom plate that enhances stability and durability.
❈This device has the potential to work in almost any kind of condition and its body is waterproof. There are no limitations when you are using Leica Disto D2 to get the desired results.
#5 - ieGeek Laser Distance Measure:
Iegeek has the potential to compete with bigger brands due to its features, and advanced functions. from the accuracy of a device to the waterproof rating, you can use this device on any kind of job site or for any home task.
Features:
❈This digital device offers indirect Pythagoras measurement, and from the area, distance to addition, subtraction, this device is loaded with all the features you need.
❈There is a non-slip material around the edges for a better grip, and it has a large four-line LCD with backlit to provide visibility to a user.
❈Iegeek laser distance measure is IP54 rated, portable, compact, and has self-calibration accuracy. It’s a user-friendly device, so there will be no difficulty in operating.
#6 - Lomvum Digital Laser Distance Measure:
Lomvum is an ideal device for all the beginners out there who want to attempt small or medium-level projects. This digital device is easy to use and suitable for a newbie who doesn’t know how to operate the laser distance measure tool.
Features:
❈It can add and subtract the measurements, and work on the theory of Pythagoras. The results will be accurate, and up to the mark.
❈This device can store about 20 recent measurements in memory. It also offers other units included meter, feet, and inches. It has come up with a backlit LCD screen to read values easily.
❈This digital device is IP54 rated to protect the device from damage, and it has a wrist strap so you can carry this device easily.
Conclusion:
It’s not easy to find the top rated laser tape measure as a beginner when you are going through operating and accuracy problems. The above mentioned digital devices will only not help you in getting accurate readings, but it also provides extra features to get rid of handling issues and other difficulties. Now it’s possible to use the device in any condition and weather.
Edited by Billy Correa
Welcome to the forum Billy, Hope you enjoy the forum
KAA
Welcome. Which specific model do you have and what are your impressions so far?
Hey Billy, another Queenslander. I envy you guys being up there. I love Queensland and always try to make it my holiday destination when possible. My sister has just recently made the permanent move to the Gold Coast having had enough of Sydney. I'm too heavily invested here at the moment to make the switch, but maybe one day.
I hope you enjoy your stay her and feel free to ask anything you need.
All the best mate :thumbsup:
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
