Posted (edited)
does anyone know if a steering wheel that includes steering wheel controls would be able to fit onto a hilux with no steering wheel controls? i have a 2007 sr5, just looking for any steering wheel from a newer model hilux (2010-2015), but i want to know if everything will be compatible before i buy one. i do have an aftermarket head unit which easily programs and allows for one.
Edited by Marc Opferkuch
If the boss and spline are the same  ,be all good
Can't see why not. The steering controls really have nothing to do with how the boss or the steering shaft is configured, so I would safely say, yes.
I cannot imagine the company retool just to accommodate steering controls. It's a ridiculous assumption.
Just check the Squib /Slip Rings are the same for the Air Bag connection
It's the clockspring that could be the big issue.  Even if the plug is there, you need to make sure the clockspring actually has all the pins populated at both ends and all the wires inside the unit.
Reckon be all the same ,dont know the controls would work , Ive got a later wheel with controls on it if you like .
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
