Been doing some painting
MR22ZZ
gold to match the rims...
masking the VVTLi and the Toyota rings too ages steps were like this
1. Take engine cover off car.... der
2. apply degreaser to all surfaces then clean off with water and let dry
3. apply 1st coat of primer and let dry for 20 mins
4. apply 2nd coat of primer and let dry for 20 mins
5. mask off any surface you do not want to be painted gold (this took ages but was worth it)
6. paint 1st gold layer allow 40 mins to dry
7. paint 2nd gold layer allow 40 mins to dry
8. paint 3rd gold layer allow 40 mins to dry (touch dry)
9. HAND PAINT toyota rings and L in red :)
I used Septone plastic adhesion primer (spray can) on everything and Septone Gold Chrome paint (spray can) on top. The red was just some old model high gloss acrylic I have left over from my F1 model building days :D
Just need to apply a clear coat to it now and it's all done... :)
but there is more to come..... :ph34r::ph34r::ph34r::ph34r::ph34r::ph34r::ph34r::ph34r:
thats awesome man!
im just gonna send mine off when i get the wingtips and grille painted so its all the same colour, but DIY is awesome too. neat little instructions u put up, could almost qualified for a workshop submission? me thinks so.
daaAaMMss looks really good Dylan!
i also need to do something like that to got with my Gold rims i got.. hmmmmm
how bout u come and do mine and ill might give u, ur other throwover! amuahahaha :P
I'll have to see how much paint I have left over after I finish everything... but if you want to leave the cover with me I could work something out ;)
I'm serious though Mario... if you want it done the same colour I could do it for you with what I have left
I have nearly 3/4 of the can after this and only a few small things :ph34r: to paint, there should be enough left over if you want. :)
wow going nuts with the painting... love the rear badges... were they easy to stick back on?
did you basically paint everything you could remove? :P
looks good mate... im going to have to start painting some of my things soonly...
    2. 3
      Toyota Landcruiser problems
    4. 13
      300 series turbo issues
    5. 55
      Stout Owners
    6. 13
    7. 8
    8. 55
      Stout Owners
    9. 2
      New Member
