Weight Reduction
Thought I would create a thread which lists the weight of various parts and mods in the Corolla. I haven't pulled my car apart yet, but if anyone does it on the odd drag day occasion (or boredom) then would you be willing to weigh your parts? So we can have a list just like the Celica fellas do in this link. Even though a lot of parts will carry over, some parts will be different.
So far I have;
Stock
Interior
Jack and tray: 3kg
Tool set tray: 1kg
Spare wheel cover: 3.5kg
Pacel shelf: 1kg
(Leather)
Rear seat side bolsters: 0.5kg
Rear left seat back: 8kg
Rear right seat back: 12kg
Rear inside side trims: 0.5kg
Rear left seat: 3kg
Rear right seat: 4.5kg
Front passanger seat: 17kg
Trim behind rear seats: 1.5kg
Rear 3 headrests: 2kg
Gear knob: 0.6kg
Exterior/Mechanical
Corolla 'Talon' option rim: 8kg (6 spoke)
Corolla 'Incisor' option rim: ??kg (8 spoke)
Corolla 6 spoke rim: ??kg
Corolla steelie: ??kg
Sportivo rim: 9.0kg
Sportivo tyre: 8.5kg
Rear anti-roll bar: 2kg
Suspension struts and springs (x4): 23kg
2ZZ axle back: 13kg
Taillight (each): 2.0kg
Intake (complete): 2.4kg
Front anti-roll bar: 5kg
2zz Front brake rotors: 15kg (pair)
Toyota Battery: 11kg
Engine (1zz)
Flywheel 1zz: 7.5kg
Engine (2zz)
Block: 17.5kg
Pressure Plate: 3.5kg
Clutch (OEM): 1.0kg
Flywheel 2zz: 6kg
Waterpump: 0.5kg
Acc. Cover: 1.5kg
Crankshaft: 12.5kg
Crank Cradle: 9.5kg
Oil Cooler: 1.0kg
Belt Tensioner: 1.5kg
Crank Pulley: 1.3kg
Sump: 2.0kg
Water Pump Pulley: 0.7kg
Mods
Suspension
Cusco Zero 2: 25.9kg
D2 Coilovers: 22kg
TRD rear strut brace: 2.0kg
TRD rear anti roll (sway) bar: 3kg
Whiteline front anti-roll (sway) bar: 6kg
Whiteline front strut brace: 1.5kg
Performance
CES CAI (2ZZ): 4kg
Flywheel 1zz
JUN (chromoly): 4.5kg
Toda (chromoly): 4.4kg
TRD (cromoly): 5.45kg
C-One (chromoly): 4.5kg
Fidanza (aluminium): 3.85kg
Unorthodox (aluminium): 4.1kg
Flywheel 2zz
TRD (chromoly): 4.7kg
C-One Type R (chromoly): 4.0kg
Fidanza (aluminium): 3.4kg
JUN (chromoly): 4.4kg
Other
Petrol: approx.: 0.75kg/L :P
Toyota Tow Bar (without tongue and ball): 12kg
Toytoa Tow Bar Tongue and Ball: 4kg
Braille Light Weight Battery: 5.5kg
Complete weight
Silva's Sportivo: 1310kg (with full tank, driver and interior)
Also if anyone has weighed their cars that would be useful, and if any mods feel like it they can go ahead and add stuff to the list.
Edited by SuperDave
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Interesting thread
I think the best weight reduction to is to lose some kilos around the waist.
I'll weight my 18 inch wheel and whiteline front sway bar tommorow.
Stock 1zz suspension weight 23kg (all 4)..i had to weight them to get a quote for postage...
im sure and upgraded system would be around the same! But really you wouldnt strip your sus for racing now would you! :D
HAHA... quick we need to lose weight... the suspension! :D :lol:
ahh... yeah ive got no weights, but the suspension thing amused me...
ooh wait, carputer... about 3kg in total... maybe... the screen and screen mount is about 200g, its crazy light!
coilovers are lighter I think ;)
i did say about the same! someone have the weight for coil overs? What about king springs?
As every gram count when trying to lose weight..its a good comparision...see if the coilover will weight more or less than the stock...... :P
i can't take that out, Ashley and I will lose our seat :o
thanks to Corey i no longer have a baby knob... and that weighs a few hundred grams.... :blink:
Im a little lost with this comment... although it may be my dodgy mind
The baby restraint clip thing in the boot i think shes talking about!
Wei Wei beats you Pete :P
I think Zee would be pretty close too
Shoot! i probably weigh a kilo or 2 more now! <_<
I played rugga too! Wanna start again!
      Mighty 1991 2WD Hilux lives to fight another day
    2. 6
      Help - Blowing white smoke
      With Toyota entering Aus Super Car racing
      Passenger footwell wet ? roofracks?
    5. 26
      Head unit sd card issue
      Toyota Prius 2012 code
    7. 2
      Engine and radiator leakages
    8. 4
      2018 SL. Reversing camera display stopped being animated.
    9. 1
    10. 2
