biggest tyres for 17/7 in 1zzfe sedan without hit the guard
trd
i am just concering about the front not the rear as the car is FF. would it be safety to use 225/45/17 for all corners with out hitting the guard and the mud flap?
TRD
  • 4 weeks later...
when you do 100km/h you'll be doing 102.5km/h with 225/45/R17
you'll have sidewall deflection also, plus the cornering ability won't be as good I think.
It's comfy fair enough, but yeech...I wouln't do it.
When I grab 17's I'm getting 215/40.
215/40, They are quite expensive and it is not availiable in all the brands since it is not a common profile. I did a search for it before. :huh:
Not too expensive Sheldon...
Yokohama a.drives are in 215/40 and are $250 ea I think...(the ones I'm already running, which are very good, but promise to be awesome in 215/40 on a 17in rim with less sidewall flex etc).
Toyo Proxes also have a wide range in 215/40 as well.
Bridgestone have nothing in the 215/40 range for the Potenza's unfortunatley. I understand my speedo will be put out a little as a result, but ultimately this seems to be the better profile for handling w. 17's, but it's only marginal.
Wheel offset plays a HUGE role.
There's 215/45 R18 89W for Bridgestone Potenza RE050A, maybe they have it in 17s? They are good tyres, even the Ferrari F430 uses them as OEM :P If anyone wants 225/45 R17 ultra-high performance tyres for track and street i have Potenza RE070s, stiffer sidewall than any other tyre you can get on the market ;)
Edited by ZEEROLLA
the widest are 215/40r17... or 205/45r17
note that not all 215 tires are 215mm wide, some are wider, some are narrower.
the offset of the rims also plays a big role here too.
If I grab 17x7.5 I'm even contemplating 225/40...if I can find them.
could still be 215/40 for me man
NO ONE makes 225/40 in australia rofl, dare I say the whole of oceania...or the world? lol
225/45 will be pretty chunky on a 17 :( I'll run some calculations...
EDIT: I'm running 205/55 on my stock 16's atm, and the 225/45R17 will be 3mm taller and a 20mm wider also :S
I reckon the 205/55 look phat...but 225/45 will be phat as man. Speedo is put a bit too. when you're doing 100km/h it's really doing 102.2km/h.
Edited by bADbOYz
i know who u got those tyres off zee :P
haha the RedSnail is pretty well know up there i guess :lol: yeh i got it off him, was hunting around for 17s to fit but finally decided to stick with my 18s ;) so these tyres have to go, simple as that.
:D That's the idea.
Wahaha...go the chunky look lol. I have that atm, there's a bit of sidewall flex though dammit :(
17's here I cometh.
im new when it comes to tyre selection.. but for my ascent what about.. 205-40-17 80w ?
they are in the package i m looking at..
any thoughts?
Cheers C-rolla
    2. 3
      Toyota Landcruiser problems
    4. 13
      300 series turbo issues
    5. 55
      Stout Owners
    6. 13
    7. 8
    8. 55
      Stout Owners
    9. 2
      New Member
