Hahahaha you guys are comedians :clap:
I'm picking up my plastic personalised plates tomorrow so I have to do it all over again! Lol. I'll be using that sticky foam as mentioned by Rollin Blk and Az :)
Here we go boys
ZERO vibration - I recommend plastic plates and door frame weather strips :)
  • 1 year later...
Another way is to raise the plate away from the car by putting one or two nuts on the screw between the plate and car.
how do you remove the rear license plate screw...
i tried but it just wont unscrew! its soo fricken tight!
Haha nice work digging up this thread, brings back memories :toast::clap:
Do you have standard Toyota screws? I replaced mine with stainless steel allen-key ones for a nice little detail on the car.
If you've never ever removed your plates then there might be rust or calcium or something built up and dried in the holes so the screws might be stuck... try WD40?
hehehe
im good at digging up old threads..
i think it has never been replaced...
i tried to remove it a yr ago.. but it was so tight that i thought theres something behind it...
WD40.. ok thx man!
I fixed mine by cutting a piece of thin foam (5ish mm thick) to the size of the place and bolting it behind the plate
i also sound deadened my boot and also put a layer of sound deadening on the backside of the number plates. Worked a treat. The only thing that rattles now is the rear window wiper.
No real way to stop that.
just weighing up the options.
DIY and hopefully i do it all well..
or get someoen to do it and pay ***** load of money! ><
man.. i sprayed sooo much wd40... n it still wont unscrew!!
my hand is red now!! :angry:
Are you turning the screwdriver the correct way?
LOL I should hope so
<_< <_< <_< <_< <_< <_<
of course i did! well i tried both ways.. lol
LOL you should have PM'd me, I don't usually check all the threads all the time.
Anyways... Mine came off rather easily by hand.
Try a longer screwdriver or one with a better grip.
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
