vibrating / feels out of balance etc
Fuel gauge wander
Hi guys. I have a 2002 Toyota Coaster and have changed my fuel tank sender and when I drive the fuel gage needle moves up and down about 1/8th of a tank depending on if I am accelerating or decelerating. I can’t personally remember if it used to do this before I changed the faulty sender or not. Just today I removed the instrument cluster and changed out the caps on the two boards for the fuel/temp and the tachometer gauge sets and reinstalled but no difference. I checked the orientation of the sender, however it can only go in one way or the screws don’t line up. Not sure if this slosh wander of the gauge is normal for the Coaster as it doesn’t do it in my Hiace. Just wondering if anyone has some suggestions? -
41
gas smell when driving hard/takes long to start
Update: issue came back but worse with rough idling / running a year or so ago. Mechanic diagnosed it as an air filter out of place and reset the codes - issue solved for good. Car is now at 380k and running stronger than ever !😊 -
O2 sensor issues
Hi everyone, My kluger 2009 with 137250 kms was having P0420 code so I have installed a new O2 sensor now it shows different codes every time it will be P0032 and P2195 and so on what would be the exact reason for this please help solving this. 🙏🏻 -
2012 Hilux with snorkel stopped after getting stuck in water
Hi guys, my sons 2012 Hilux (diesel) engine stopped when he got stuck in a deep mudhole last night. I had a quick look after driving for about 130km with a car trailer to get his car and it has been immersed in muddy water over the top of the battery. The water level on the inside of the car apparently reached top of seat height before they managed to snatch it out of the water. The car has a snorkel, however, the engine stopped whilst the hilux was still immersed in the water up to its bonnet. What would have caused the engine to stop? Typically what would one expect to need to clean out, replace etc in order to sort this? -
21
FUEL WARNING MESSAGE
Definitely can't get the pump out through the hole in the floor. The top of the pump has a larger diameter than the hole. 2nd pump has arrived from the wrecker. I will be removing the tank and installing it today. -
21
Jeez that's unfortunate. Here's hoping the next one makes it to the right place. I've spent a long time looking, but I haven't seen any videos or images where that mechanism has come out through the inspection hole - I really hope I've just been looking in the wrong place! I've got my fingers crossed for you Geoff!! -
MWR Oil Pump
Thanks for your response, I’m just hoping and praying that the oil pump will withstand the over-revving which is why I purchased the product. Also, I know very well about the flaws of the 2ZZ in regards to the oil pump and oil sump.- oilpump
- toyotacelica
(and 1 more)
Tagged with:
MWR Oil Pump
MWR are a reasonably respected name in the aftermarket 2ZZ business, they're not the cheapest (especially with shipping) but the products are usually solid. In this case though it is only the oil pump gear itself which is upgraded (as that was the issue with the stock ones), the housing is new/refurbed OEM Toyota/Aisin. FYI 4340 is the grade used, it's a high-tensile chrome-moly steel. I believe the stock ones are sintered (ie powdered steel pressed in to shape at high pressure/temperature), which contributes to their propensity to shattering (although I think it is much rarer than people are lead to believe, and usually as a result of over-revving via mis-shifting)- 1
- oilpump
- toyotacelica
(and 1 more)
Tagged with:
I left my fridge on in car for five days and it completely ran the battery flat. I have replaced with new battery and engine starts but only idols cannot be revved at all. Any ideas?
