2007 Corolla Sedan rear seatbelt question
Hi everyone, new member here. I've got a small problem which I'm hoping you can help me sort out. I've read the "read me first" thread and done a forum search so apologies if this ends up being a repost. Ok, so I've just has a bloody mouse chew through the rear seat and half (but only half) of every rear seatbelt. Which is nice. So I need to replace them. The problem I appear to have is that none of the local breakers have any suitable vehicles that I can pull them from and the ones I ordered and was sent from the bay of fleas has the wrong brackets on, despite being allegedly for that vehicle. Further searches come up with every seller showing the wrong bracket, so either I've got a special car which is different just because, or (more likely) they don't know their ****s from their elbows what they're selling. I'm after some aftermarket ones as they never get used and just need to be there to get through rego so don't really want to spend a heap of cash I don't have on genuine parts if I can avoid it. I've replaced the centre one (a mate just randomly had it in a box in his shed, which was handy) but still need the left and right. I've attached the bracket type I pulled from the car and need. Is this a standard generic Toyota seatbelt or specific to the 2007 Corolla sedan? Does is need to be specifically for the rear left and right or do front ones fit? Does anyone know where I can source an aftermarket pair? I will really, really appreciate any help offered with this, I know my way around a box of tools but very little about mechanikicing (which is part of the reason why I bought this car - something simple to learn on as repairs/replacements become due) and this is a simple fix which is turning into a drawn out headache. Thanks - Matt -
Hi from Wagga
Hi folks, I'm in Wagga, have what I thought was a nice, cheap and reliable 2007 Corolla, and am joining in the hope of picking the collective brain to troubleshoot and avoid tossing my computer and the relevant car parts out of the nearest window. I'll play nice and restrict the swearing to off line areas :D See you on the threads! Cheers Matt -
Amplifier 88650-60D60 no longer made
Cheers Herb, I've tried all of the UAE, New Zealand wreckers, even Aman with no luck. Very frustrating... -
Hi Paul, Try this mob, they seem to have everything. Genuine Japanese Car Part Imports - Amayama Herb -
Hi all, Wondering if anyone has had this issue. I recently purchased a 2007 200 series landcruiser, and the amplifier for the air con unit stopped working. Part number 88650-60D60. (Looks like a circuit board) All controls for the air con now do not work, very frustrating in winter when you dont have any way to unfog your windscreen. Toyota have informed me that they no longer produce this part, and there is nothing superseeded to fit in it's place. My question is has anyone had this problem? If so what did you do to fix it? I have got onto an auto sparky who has had a go at fixing the circuit board but its unserviceable. Any feedback would be much appreciated. -
Engine oil dipstick reading
Hi guys, Probably a silly question... I'm having trouble reading my engine oil dipstick on my Toyota Hilux 2010 3.0 Turbo Diesel. I have warmed up the engine, turned off for ~10 minutes, parked on a level surface. Pulled out the dipstick, wipe it and insert it back to the bottom and carefully lift it up. I tried so many times and the two sides always look different. I couldn't read it. Maybe I just don't understand how to read it. Could someone help? Thanks a lot!!! -
Landcruiser 13B Engine Swap
Hi I’m not shore how you went with this project but on a whim how did you go and do you still have the old 13b engine as I have this car and the engine failed looking for options cheers -
RN105 G52 gearbox Automatc to Manual
hi I have a 1992 RN105 22R with a G52 box, can i use an automatic gearbox from a donor vehicle (1991 4runner 3vze) and make it work in my manual ? -
Lock CH-R
Just got a used 2018 CH-R, I always have to lock the car by pressing lock twice to have the light turn off. A friend borrowed it and pressed lock only once and the battery died because all the lights were still on. Is that normal? Shouldn’t one press of lock on the key switch off everything? -
1999 Corolla CS-X 1.8 low 54,000KLM. for sale
Meticulously cared for, one owner, classic 1999 Toyota CSX, 1.8L Twin Cam with less than 54K on clock. Always serviced and garaged. Full receipt history and providence available. Paintwork, seats, carpet and engine in near new condition, no rust, no accidents. (minor stone chips on bonnet). ABS brakes, driver + pass. airbags, auto windows, auto door locks, 6 CD stacker. All working. This near perfect gem, runs like a dream with power to spare, asking $6000 ONO. IMG_6776.HEIC IMG_6796.HEIC IMG_6806.HEIC IMG_6807.HEIC IMG_E6775.HEIC IMG_E6790.HEIC IMG_E6792.HEIC IMG_E6803.HEIC
