Sydney Monthly Meet - Last Sat of every month at Villawood usual spot
Dashlight dimmer
I scored a nice fairly low kms 1992 toyota starlet as a run about for work,my problem is at nighttime the dashlights are very dim and the clock is almost non existant,ive searched the dash from top to bottom and cant find a knob,switch or anything else to do with adjusting the dashlights...can anyone help me with this problem? -
Electrical issues
Hi all him having some issues with my 2018 prado. Head lights keep flickering when I put high beams on now head lights won't self turn off also reverse camera takes ages to work and Stereo randomly turns of and back on when I'm driving just wondering what it could be -
New member
hi all, im Neil,i live in new zealand & ive just scored a 1992 toyota starlet soliol -
Rav4 2016 ZSA42R 2WD CVT failure
Hi Andrew, just wanted to see if you were able to get this fixed? What was the issue in the end? My car has just started making this same noise (2016 Rav4 - 97000km) and I'm worried. I've had the transmission fluid checked and replaced but the noise is still there. -
buying landcruiser 80 auto vs landcruiser 100 manual
Hello, just need advise which one to buy $6000 landcruiser 80 automatic or $8000 landcruiser 100 manual both 350k odometer -
Gen 6 Cluster Backlighting Issues
When the fuse blows do your f & R parking lights still light up -
Hilux surf
Hi guys I have a 1994 hilux surf and the engine light comes on sometimes I've had it looked at and it has a code g26 the mechanic is not sure what it is dose anyone know what it could be also it won't rev past 3k -
6
Buying a Hilux / Surf
Hi all I need advice I have a 94 hilux surf and it has a code g26 and won't rev past 3k I've taken it to a mechanic but they are not sure what it is has been scanned but nothing anyone have have the same -
05 hiace ecu
Hi all, new member needing some help with an issue that has me stumped, replacing ignition and had a short somehow. Van would not crank or obviously start, found blown fuse and replaced, now car cranks but won’t start, no check engine light when ignition is first turned on and scan tool will not communicate with ecu. All fuses good except fuse 26 on instrument panel fuse box has no power. almost convinced my ecu is cooked but before outlaying for a new one thought someone may either advise another possible cause or confirm ecu likely the issue, appreciate any advise or experience similar. -
1989 Hilux Low Voltage
Hey all, recently got a 1989 Hilux with the petrol 22r engine. I had plugged a voltage meter into the 12v socket because I suspected an electrical problem as the battery light had been on. It had read 11.9 volts initially but the more I drive the more it deteriorates, currently sitting at 10.9 (after several hours of driving) when the engine is running. This obviously doesn't charge the battery and it can't start by itself. I have since replaced the battery and yesterday I did the alternator with a brand new one. I've checked all the grounds that I can see but it's still sitting at 10.9 volts and deteriorates over time. I was thinking the voltage regulator is the next best bet? I looked at it visually and it seems fine. Anyone got any other ideas? Note: I had a very long drive the other week and on one occasion the voltage spiked back up to 15+ volts for a short while before going back down to about 11.4 And yeah I'm trying not to drive it too much because I know it's probably damaging the battery being on such low voltage. Any help would be awesome thanks!
