SV_21 Camry
Gearbox issue
Just a thought, you haven't by chance installed a thick rubber mat or some other floor covering down that's preventing the clutch pedal from going all the way to the floor, and its preventing it from fully disengaging, Check your freeplay and adjust it accordingly from under the dash on the pedal itself, loosen the locknut, adjust the pedal height and freeplay -
Street Signs from Hell
The first picture was photographed by myself somewhere on the Warrego HWY QLD, the others are all copied off the Internet, and need not even be located in Australia. Hidden Sign .mp4 -
Street Signs that are Naturally Humorous
The "Bitsch" sign is located in Switzerland and was photographed by me, way back in 2013. The other sign was merely copied off the internet, but is still a genuine place-name, not just Photoshop. -
Street Signs that were Humorously Altered
These were all photographed by myself over many years. -
sportivo body parts on prodigy?
hey was wondering what the best option is on fitting sportivo body parts on a 2010 aurion prodigy. i just like the look of the sportivo body kit better. are the parts interchangable? was only gonna do front and rear bumper and grille any advice would be awesome cheers- 1
I have three remotes for my car but only one works
Tried holding it closer and it still didn't work. Might have to take it into Toyota -
I have a 2017 and I warm it up, you will hear and feel the difference sound. -
Hey so to start with this video is useful I know you may have done all this etc but the key part is that he puts the remote fob near the right hand side of the wheel he is putting it close to the dash as that is where the programming signal comes from. with all the signal interference constantly around proximity can help a great deal. new battery or check battery in the fobs as well. I did see a way with other cars to use a working key fob to programme the others this may be a option but not sure. -
Dual Fuel (LPG Petrol) FZJ105 in Adelaide - What to do with?
Hi all, Per subject dont know what to do with my cruiser - LPG availability is getting quite low in Adelaide so I either need to remove the LPG or sell it to someone where LPG is stronger (Melbourne for example). Nothing wrong with it but I would be happy to part with it - unsure what to do Thoughts?
