Hey guys,
I plan on purchasing a Sportivo in the next month or so and after reading the forums have noticed there are a few niggling issues with the sportivo. Some that i can think of that i have read are:
Gear Selector Cables
Brake Noise
Dash Noise
So... just wondering if you guys can give me a short description of the problems experienced with your sportivo and whether or not they have been fixed so i know what to look out for.
Cheers
  • Replies 84
  • Created
  • Last Reply
Top Posters In This Topic
There are a few probs with the car but not sure if the fixes are permanent.
My car has the vibration in da dash which is linked to the gear selector cable. I've got it booked for the 6th Jan to get that fixed. Also the braking noise only occurs sometimes, mostly when the car has been sitting there for a while and then u go to reverse it. They are the main problems. Other than that, it is a sik ***** car! :)
I have been lucky up till now. Although my car has only done around 1500k the only problem with my car has been the hand brake needed tightening up. I have not had any dash vibrations or gear selector problems...........YET. :unsure:
I have found that the vibrations in the dash come gradually - Mine started off barely noticeable, but now is progressed to an irritating level that you can really notice it as it competes with the radio.
I contacted toyota australia about it and got a reply that there won't be a recall on the vehicle to have it fixed, and that we should report it to the dealership who will then log the problem with toyota technical services.
man i've had mine now for 6month 17,000 km only prob brake noise fixed with 17" wheels, and suspension mods,
If it's a gradual thing....
then..can't it be tightened or something shock obsorbed....
just means something is loose..which means it can be tightened..right?
or is it not as simple as that. <_<
I don't thnk its as simple as tightening something. That is why they need to change the gear selector cable which apparently is not a permanent fix. Mine rattled as soon as I got the car.
MY CAR IS A LEMON!! :(
the gear selector cable is the one that goes from the gear stick to the actual mechanical 'thingy' that changes the gears.
does anyone know WHY it's faulty?
Like...the technical reasons why.
cant u just rap it up in a thin layer of foam or sumthing that will not make noise when it viabrates?
if i get it ill fix the *****! ill do anyhting to get rid of this noise, from what ive heard its pretty load.
yeah, that's what i meant...like an easy fix like that...
Hey guys...this is my first post here, so hi :D
I picked up my Sportivo from the dealer a couple of days ago...had a Sat. Nat. unit fitted as an extra...working fine until last night, it will not start/light up/operate/nothing, can't even get audio to come on. Blank Screen. It seemed to stop working after I stalled the car *blush*
I'm taking it to the dealer tomorrow to get it looked at but being Jan. 1st today I was hoping someone may be able to suggest some possible solutions?
Thanx in advance.
just because you stalled it..the audio system/sat nav won't work???
strange... :huh:
strange... :huh:
No I didn't say that dude ;)
I'll post back what the problem is once the dealer looks at it.
strange... :huh:
where did u get that he stalled it?:
i didnt see him mention that anywher tiger? :(
thought: i'm sure L-Rec said it seemed to stop working after he stalled it....
hmmm...maybe i had to much to drink... ;)
stalled: meaning...make the engine turn off...right??
Took my car for the first 1000 kilometre service today for the vibrating noisy dash, and handbrake adjustment.
Funny thing was that the dude at the service desk asked if I had modified it with for example 17 inch wheels - I said no its stock standard. I get the impression that he was going to void my warranty or something... if I did.
Anyway, hope they can fix the annoying vibration noises - that's what really concerns me at the moment.
Bit.
Yeh I did mention it all went kaput after I stalled. It was working fine before that. But I doubt there is any relationship. That's what I mean. Just find it weird that is just does not operate anymore. I'm clueless on electronics.
I'm taking it in to the dealer on Monday to have a have look. Its probably something simple like a reset switch. I dunno *shrug*.
Just picked up my car and all the problems have been fixed. :D
Apparently they use some rubber to dampen the gear selector cables vibrations so no need to change them for new ones. I'm glad there is a solution even though its a design problem.
sharmz: maybe we both had too much too drink? ;) :huh: :P
Hi Guys,
This is my first post. I purchased my sportivo back in september and have literally been contacting toyota every few days for an update as to whats going in with all these bloody issues. Besides probably getting the run around for the first 2 months a few threats to take them to small goods court and seek a refund finally got some bloody action. I've had it in service about 5 times over the last 3 months to fix all these niggly porblems. And everyone other than the management staff have been helpful as the managers have all simply been idiots as soon as i signed the dotted line to take the car. I have had the selector cables changed 3 times, the clutch plate replaced to supposidly stop the grinding noise when changing from 2nd to 3rd (this problem has now gone away) but still that damn rattling. I am booked in for Tuesday 6th to apparently try a new solution or something that toyota technical has come up with as i went to the extent of actually getting one of the toyota technical guys out in the car with me just to show hey this is really ****** people off. So they have rushed something up from melbrourne which they will install on Tuesday will let you know how it goes.
If your wondering i purchased my car from blacktown lander.
Lander Toyota SUCKS BIG HAIRY B@LL$!!!
i bought my levin from them...and after i signed the paperwork...and got the car..
they wouldn't give me the money they owned me for paying off my trade-in.
at one stage..they told me it was coming in the mail for 2 months...and then the finance person ACTUALLY told me to stop callling him...all because..
"you've got a good deal, why do you want more money".....
that was it!
i RANG EVERDAY asking for my money...they owed me $800 or so bucks...
and i finally got the check....after 3 months...
they suck big time!!!!
<_< hahah yeah it seems both penrith and lander have there issues.
if u want a good dealership with great service im telling you guys, you cant go past castle hill.
i bought my car from there and i service it only there.
and i live in penrith so to drive to castle hill for a 9am service is h00j, but damn atleast i have peace of mind and am not ****** off with my service or anything...
I bought my car at Peter Warren in Warick Farm. So far it's pretty good service for me. Takes a long time to do anything though but they are pretty friendly and helpful.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
