Snapped Wing Mirror (RHS) - Corolla 2001
N80 2015-2017 infotainment upgrade
I have just installed a interface behind my factory unit which is all plug and play I now have wireless or corded apple carplay and android auto wanted to share on here to make aware there is a option with out having to buy a whole new stereo all the functions work ie steering wheel controls and reverse camera and all the factory options in the stereo are retained also I am soo impressed I am now supplying worldwide -
Hello There
Will be starting to do body work and painting hzj 75. Will be looking for info. Removing panels, etc. Thanks -
Central locking
I have a land cruiser HDJ100R 2001. I have changed the remote batteries and tried to reprogram the system, the remote will lock the car but want unlock the car. Can unlock the drivers door with key but won't unlock any other doors. I can unlock the passengers side door with key but no other the key will lock the tail gate but won't unlock it. The remote will lock the car and you can hear it clicking to try to unlock. If anyone has any ideas what I can do to fix this problem. I rang around trying to see a local auto electrician. but they are busy till next week. Thanking You HDJTom -
El44 Paseo distributor
Anyone? After some research I think the toyota dizzy I need is 19050-11010. I went to local toyota wreckers and asked for a dizzy for Sao (as other wreckers paseo engine been pulled along with dizzy) And they sold me a ep91 starlet dizzy looks Identical from out side diff toyota p/n 19020-11380 stripped apart and compared Insides similar but the starlet one has an igniter module built inside dizzy and Sao has igniter module in engine bay on firewall. The toyota wreckers reckon it'll work but I can't see how it can. As different p/n and different internals and different colour wires but same 4way wire connector and 2 way. Can anyone confirm please? ep91 starlet dizzy top El44 paseo dizzy below -
Brake Rotors 2013 Toyota LC200
Used front and rear rotors to fit 2013 LC200. Front 340mm, rears 350mm. Travelled 90,000km. No lip, never machined. Rears 18mm thick, fronts 32mm thickPads are for reference to illustrate wear. You are welcome to take them with the rotors. Pickup from Beachmere, QLD -
2019 camry ascent sports does not have android auto
Look up TEYES. They should have something you need. Make sure you choose 2k as an upgrade for better phone reception. -
Toyota Allex/ Run X headlight retainer clip
Why don’t you just get the clip? -
Hi, does anybody have any of these lying around that they don’t need? or do you guys know where I could get one? I seem to have misplaced the other one years ago. or is there a way for me to bypass this retainer clip and just use an aftermarket bulb setup that just fits the housing?
