Where to go to get my discs machined
neK
About a year ago i got changed my brake pads to EBC green stuff, but silly me never bothered to get the discs machined.
Now these brake pads are pretty much worn, and my discs are no longer smooth
To give you an indication if you run your finger along it here how it would feel
Its wobbly from the inside, and on the edge of the disc its a massive bump, its like the pad never made contact with it.
Anyways, Im looking to get these fixed properly. Can anyone recommend a good brake place in Sydney that will supply and fit new brake pads, and machine my discs?
And how much will it cost?
Or am i beter off getting new discs altogether?
Edited by neK
Measure the disc thickness and see if they are still ok to be machined...
(Machining will take off around 1mm so check that against the minimum disc thickness)...
If they are ok to be machined, AGA Enginnering in Artarmon can machine them for you... We use them for all our machining and engineering needs at work...
If they are undersize or will be undersize if you machine them, replace the discs and pads...
If you're going to use a co****r brake pad, then you should upgrade to better quality discs that will last longer with the pads you choose...
Is this them?
A.G.A. Engineering
40 Hotham Pde Artarmon NSW 2064
p: (02) 99062966
Btw, how much should machining the discs cost?
And any recommendation on brake pads, i was thinking just going back to the toyota oem ones.
