Baseline DYNO Sheets
Danthuyer
  • 5 months later...
I had my 1st dyno run on Saturday.
Peak hp: 107.4 kW
Gear: 4th
Dyno: Dyno Dynamics
Mode: Not sure (I assume shootout)
Ambient: 36 Celsius
Fuel: 95 RON
Not bad for my only engine mod being the CAI, considering I had crappy fuel and the hot day. But what's with the torque hole low down in the rev range?
Anyway, scans for kW against AFR and kW against torque (N, not Nm) are below:
Edited by oz_viking
Completely stock-as-a-rock, AUG 2004 Pre-facelift Toyota Corolla Sportivo Dyno attached.
Peak hp: 107.2 kW (at the wheels)
Gear: 4th
Dyno: Dyno Dynamics
Mode: ShoutOut
Ambient: 25 Celsius
Fuel: 95 RON
Tyre Pressure: 40psi
Edited by sport1vo
  • 3 months later...
Power @ wheels with TRD CAI and BP Ultimate fuel: 114.1kw @ wheels
Dyno Dynamics 4WD Dyno in Shootout Mode
Gear: 4th
Ambient Temp: 19
Tyre Pressure: 34psi (although it says 50psi)
Edited by ZEEROLLA
  • 4 months later...
  • 7 months later...
      maps in 2017 Camry Altise
    3. 5
    4. 4
      Front Cameras
    6. 51
    7. 51
      1kzte throttle body
      Aftermarket parking sensor
