My 2zz N/A Project
as has been stated before ..... the only off the shelf products available which are as close as possible to being plug and play are:
Motec (You will need to buy the added optional units to get this totally working with a 2zz), Apexi Power FC (requires some fiddling to work it with a corolla) & Hydra EMS (claims they have a corolla friendly version)
other which have been stated to work however my understand is they are simply plug and play:
AEM (MWR got the AEM's going even though they arent for the 2zz), Autronic (the CES turbo car runs this) & adaptronic (wont work on MAF and will need some fiddling to emulate lift engagement)
as stated by Neil and i personally dont think to date haltech has sorted something out for the 2zz. This is the extent of my knowledge when it comes to the 2zz ECU options.
Nope, Motec im pretty sure is a complete unit now. PFC is close to plug and play, but as I stated before it has some shortcomings with regards to variable cam control as well. no idea about the Hydra EMS either. I am interested to see this AEM ECU though.
mate unless the M400 comes built in with its cam controlling mechanism now i think ur mistake :P :P :P :P :P
what fuel are you hoping to use with the 13.1 comp pistons?
To a full tank of gas i use 2 bottles of octane boost but thats y i have ordered a aquamist kit
Just thought I would add those octane boosters really only end up boosting the octane rating of your fuel by about 0.7 (even with 2 bottles), so I wouldn't be dependent on them to run your 13:1 pistons...
0.7 higher if your lucky.. your going to have to buy some race fuel by the drum$$.. wat octane (fuel) do you need to run this sort of gear??
at least 100+ octane. an avgas/fuel mix would be good but you cannot buy avgas anymore. Racing fuels like elf are very expensive, however i suppose you could use them on the street.
If you have a choice, I definitely recommend the Mahle pistons.
The Wiseco pistons give a lower compression ratio than standard, even though 12:1 is claimed. They also have relatively sharp corners on the valve cutouts, which is likely to be a gas flow restriction.
I always check short motor static peak turning torque during assembly and the Mahle pistons show much lower friction than the Wisecos. Very importantly, the Mahle pistons give exactly the compression ratio the manufacturer claims.
Neil
Mate contact CES here in Brisbane Australia as I know they have sent exhaust systems overseas before for the Sportivo. Tell them what you are doing and see if they can help you out.
http://www.cesracing.com.au/
All their contact details are on the website.
i have a question for the forum i'm thinkin about stroking the engine i was wonderin if anyone know wat connectin rod r used in the stroker kit i jus happen to get my hands on a 1zz fe crank
I'm pretty sure they use custom Crower rods, and you can only get them from MWR. I'm unsure if you can use any piston other than the Wisco that the MWR kit was originally designed for. But contacting MWR will yield correct details and I'm sure they will sell you kit without the crank.
http://monkeywrenchracing.com/mwr_toyota_2...troker_kit.html
  • 4 weeks later...
I am officially entering the 2zz N/A horsepower race I certainly own a Japanese market (JDM) Toyota Runx/Allex and looking to get all i can out of it. Below is a list of my parts that are being installed to the car
Initial setup will be:
Engine-
TRD high compression pistons 13.1
Ported exhaust manifold
Injen cool air intake
Piper Cams stage 2
Fidanza flywheel
Special coated bearings
Circuitworx Oil Pump Gears
C-one Final Drive 4.7
TRD LSD
TRD Short Shifter
ARP Head Studs
ARP Flywheel bolts
ARP Main Bearing Bolts
ARP Connecting Rod Bolts
Stainless Steel Valves
MWR Valve Springs
TRD Clutch Kit
Port & Polish Head
TRD Tremosat
MWR Moroso Oil Pan
Aqua Mist Kit (Water Injection)
Oil Cooler
AEM Underdrive Pulley Kit
Interior Mods:
Oil Pressure Gauge
Oil Temp Gauge
Water Temp Gauge
ECU:
Apexi Power Fc
Suspension:
D2 Suspension
Cusco Front Lower Stress Bar
TRD Front Strut Brace
TRD Stabilizer Bar
Brakes:
Wilwood Calipers
Steel Braided Brake Lines
Hawk Street Pads
Misc:
GReddy Oil Catch Can
Apexi Turbo Timer
  • 4 weeks later...
      Stout Owners
    2. 12
      300 series turbo issues
    3. 8
    4. 55
      Stout Owners
    5. 2
      New Member
    7. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
