new turbo for starlet
not to much really, just put in a hks ssq (sounds freakin sweeeet) and of course the pod filter. would the tdo4 require a ecu upgrade?
Any different turbo's really need to either have your ECU piggybacked, or a new standalone ECU wired in. The standalone is a really good upgrade, regardless of if you're upgrading your turbo or not.
i m doin a project with my starlet glanza & i got a td 04,blitz fmic intercooler,autobahn88 exhaust minifold,74.5mm forged ,sard fuel pressure regulator to go on a 4eft
as we do not have a dyno in bd i would like to know what wud be ma bhp if i boost @ 22 psi (1.4 bar)
Edited by 4age freak
You can buy exhaust manifolds off ebay that have a t2 flange. ecu upgrade is not needed but advised.
They'll also break the first time you get them on a dyno - trust me, I see it almost weekly.
I had to ct9 aftermarket manifold off ebay on the mine and it held up....
Is it a stainless jobby or actually out of mild steel?
I would expect around 170ish
as an aside was on a starlet cruise on the weekend and one of the girls is running a t28 and got talking apparently very little lag and 250hp and something like 700 odd nm torque so i think i am going with a t28 rather that t25 now. Just need to save some money
700nm from a 1.3??? :blink: i wouldnt believe that
That's probably a figure quoted at the wheels. If so, then it can be believable.
Exactly...
Remember that the torque output of the engine gets multiplied by the gearbox + final drive ratio in the diff, if it was on a dyno then you'd be looking at roughly 1:1 through the gearbox and then between 3:1 and 4:1 through the diff, so that would mean 700Nm at the ground = roughly 200Nm at the fly, perfectly reasonable for a 1.3L turbo.
  • 5 years later...
Hi Everyone,
Turbo is starting to go and so i am trying to decide what is the next step. Upgrade the internals of the turbo to hybrid or upgrade the turbo entirely to ..... not sure. so just wondering what i should do.
I recommend you get a TD04, they are relatively cheap, a little bit more laggy yes, but your boost peaks would be higher also. It's almost a bolt, but I recommend you get an aftermarket ECU, if not you're going to be getting 5PSI out of it and it would be in safe mode every time.
Good Luck!
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
