Making my 96 Supra a 9-10 second car...
Lisa M. Stewart
Lisa
first of all , I would like to salute you for your amazing thinking ( Dream ) in fact I always consider Supra's to be one of the Smartest options for modification .
let me give you a quick idea that will take you a way beyond 500HP
first of all I’m assuming that you already having 2jz as the engine for your car
a lot of sites out there give you complete projects to modify your supra
as a start I suggest that you put a target in mind about whether you are willing to keep in as off-road , or street legal supra .
I highly recommend that you remove the TT and think seriously of adding a big single Turbo specially T88 ( I adore this one )
anyways you have to take into consideration a lot of things
Single turbo
Custom downpipe and mid-pipe
oil feed and return lines
install block-off plates
gear + transmission
intercooler
Suspension, Brakes, Wheels, and Tires
Greddy Profec Type-S boost controller
along with so many things ( many but not complicated if you knew the right car shop that can help you in ordering parts + installation )
I know some guys in my area managed to reach 1200HP with 2JZ without stroker ( 3L only )
anyways I highly recommend that you browse a lot of such sites to give you an idea of where shall you start . by the way if you don’t have the time , you can just buy a fully modified supra available in many sites designed to sell modified supra’s only
God Bless the Supra 4ever
^ Nader: I hope you didn't spend too long on that post. Unfortunately you may not have been around at the time that we were getting all these posts from spam-bots. This Lisa happens to be one of them. Oh well, I guess once someone sifts through the Fast and the Furious comedy, they will come across one useful answer.
saw the new one last night.
not as many funny comments.
Let this go. Before it's too late
It's already too late....
Probably the only thing I cringed at, apart from the cheesy "appreciate a fine body regardless of the make" line, the description of Dom's perfect girl before that was great though, swap the %s and it'd be the same for me.
Hahahaha... i only just found this.
In the spirit of keeping trolling alive on tocau, allow me to serenade you all.... ahem..
I wonder if you know,
How they live in Tokyo,
If you seen it then you mean it
Then you know you have to go.
Fast and furious... Drift, Drift, Drift!!!
you see him come and go out of the black Benz SLR
You wonder where he get that kind of money?
Don't worry about it
Lets go
Lisa
The car was stated as 1996 model, all models from 1993 onwards had a 2JZ.
It was stated as a non turbo so there isn't any TT to remove. A big single is only really required if you are aiming at >500HP. Hyrbrid twin turbo's can be a better option if you're happy with upto 500HP.
Single turbo
gear + transmission If it's a manual the gearbox is already good for 1000HP, with an auto a higher stall torque converter will be required
intercooler
Greddy Profec Type-S boost controller A fuel cut defender is also required to stop fuel cut at higher boost
At 500hp+ you will need to beef up the top end of the engine with stronger rods, pistons, metal head gasket, replacement ECU etc. this are big ticket items
With massive $$$ spent this is achievable, to do this without any sort of financial/sponsorship backing would be crippling.
Good advice
I know this is only spam but for anyone actually thinking of doing this I have added to some of the above post B)
Edited by Moto
      FUEL WARNING MESSAGE
    2. 30
      Classic Toyota
    5. 30
      Centre Bearing Replacement
    8. 6
