Rear mounted turbos FTL
Rear-mounted turbos FTW
They're still close to the engine :P In Le Man setups it is indeed FTW B)
I was saying more-so for front engined cars.
also sitting under at the back of the car problems like
water into filter
water onto turbo - thermal shock through the metal
long oil lines
long piping has to effect efficiency of whole setup ?
Was aware of that, couldn't help posting photos of the 7 though, it's a reminder of how awesome Toyota used to be. Put it side-by-side with a Camry and you wouldn't know they came from the same country, let alone the same manufacturer.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
