[GB] Saikou Michi oil catch can (cut-off date 8/10/09)
XploShun
  • Replies 148
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I'm happy to have these whenever everybody is ready ... No rush on my part :)
take all the time needed ... Last thing we'd want is to have incorrect fittings and measurements etc
ok.. will pm you kolourhero
but are you 2zz guys going to measure the hose?
I need the ID
i asked saikou whether he can paint the trademark... or even the can
he said he can paint the can... so i assume he can paint the trademark at least...
whos going for pink? :lol:
[edit] i can always refund! im not gonna take the money and run :P
Edited by XploShun
sorry about this hose size issue
didn't know you guys have different hoses
I'll wait until you guys can confirm what inlet/outlet nozzle size you need for the 2zz
I've asked and1 already.
need a couple 2zz owners to measure it so we can make sure its 100% correct!
site never mentioned about colour coding so i highly doubt it.
the trademarks colours are the 1s on the left of the homepage
for the can colour... will let him know with all the measurements when we pay him..
if he doesn't do it.. pick the 1 you see from his site
did a search and found this
http://au.toyotaownersclub.com/forums/inde...showtopic=12022
i have no idea what that jack au did..
but i also checked the link inside.. its in JAPANESE..
http://minkara.carview.co.jp/userid/250163...20676/note.aspx
i think CHA5E told him not to touch hose no.2 & 4 shown in that jap website.
am i right??
also the japanese install guide says the hose ID for no.1 and no.3 are both 15mm (5/8")
now guys.. go do some measuring!!
Edited by XploShun
No. 2 to No. 4 is where the oil cat can needs to sit between on a 2zz. If you undo the hose at no. 4, you'll notice some residue oil in the hose. Whereas No.3 won't have any oil in it.
No. 4 is about 21-22mm, someone needs to measure it exactly, as I have given up on trying to find hose that's 22mm and flexible.
am i right??
thx kev!
i dont know about sportivos, sorry guys!
so its no.2 & 4? not no.1 & 3?
then.. wts that jap doing?
measure the OD of the valve
just wait for mario!
am i right??
am i right??
OK count me in as well.
2zz - NSW
I'll try to help out with the hose dimensions when i get a chance to go to my car.
Just to clarify, we need measurements for all 4 points in the attatchment image?
am i right??
2zz - NSW
thx mate!
well, kev said its 2 and 4
but it doenst hurt doing all 4
added!
NOTE: this might be a noob question:...
What's the main purpose of the catch-can?
I was looking around on the net.. and still can't figure out whether i need one of these?
it separates the oil and air... and stores it... so whats the benefit? does the thing help to keep the engine run clean/cleaner ??
Normally that air/oil mixture is circulated back through the throttle body through into the intake manifold, back into the engine and burning oil is a no no.
So catch can separates the oil so that only the air goes back through.
So yes you're right. Engine runs cleaner and potentially you can make a little bit (not noticible) more power by running cleaner and not burning oil.
Here are pics of my set up
I used a 8mm hose from the pcv but I'd use a 9mm because it was so hard to get a 8mm on.
As you can see the hose on this side is huge (top hose) as some one said before 21-22mm.
Feel free to ask questions..
Awww man. and here I measured all 4 pipes. ahhh well here are the dimensions that I got. Use the image as a reference from xploshun
1: 14.07 mm : hose 13.5mm
2: 9.03 mm : hose 8.01 mm
3: 19.04 mm : hose 18.6 mm
4: 21.74 mm : hose 21.06 mm
first number is the measurement of the nose on the engine
second number is the inner diameter of the hose. I just measured this just in case lol
thx for the photos and1 and azzman for the measurements
so what do guys want?
a 21mm valve on the CAN? to match no.4? but i was told that a hose that big will be too hard to use
do you want to get 9mm valve on the can instead and get a adapter (9==>21) to connect it to the no.4
im shocked that its really that big!
its even bigger than 2JZ engines... but the other end is only 9mm.
Edited by XploShun
      Toyota Corolla Sportivo
      Toyota Landcruiser problems
    5. 7
      selling car
      Fuel Filter - Change or not
      2013 cruiser gxl ute
    8. 2
    9. 2
