300 series turbo issues
Hello, My GR is 26k and I’m having the exact same issue right now. Turbo bolt gone missing they’ve had the car for 2 days trying to find it. Did they end up finding yours, and if so where was it? What’s been the outcome with yours? -
Sub tank gauge 75 series Ute
G’day guys, got an issue with my sub tank gauge not working. I was driving the other day and noticed the gauge flickering from full to empty quite erratically then stopped working. The tank is full and there was water on the road from a recent shower. Anyone seen this before ? Cheers Matt -
Range from Cross Corolla Hybrid
Hi there, I own a 2024 Cross Corolla Hybrid with the 2 litre engine What sort of range is expected from thee vehicles? I have heard people have 800-900km range from one tank. Mine only has 600, can anyone please give me a hand with this? -
105 instrument cluster
Hi my son purchased a 105 3/2002 landcruiser petrol engine chopped tabletop, the dash cluster is not working as it should . the gauges continuoisly flicker equally in unison. tried a used dash cluster and came up with a similair problem gauges still flicker but only on elevating rpm . this has stumped more heads than just myself so I was wondering if anyone had some advice for this stump and his collaeges so we can get this car moving again -
Hilux 2020 windscreen air vent access.
It sounds like a tricky situation. Here’s a brief plan: Professional Help: If the dealership couldn’t fully resolve the issue, consider visiting a professional mechanic or auto specialist. They have the tools and experience to remove the plastic pieces safely. Dashboard Panel Removal: The top dashboard panel can usually be removed by unscrewing and prying off clips. Check your vehicle’s manual for instructions. Once removed, you should have better access to retrieve the broken pieces. Use a Vacuum: If accessible, use a small, flexible vacuum tool to help remove the debris from the vent. -
Auto-Locking doors on manual 2014 Corolla Ascent
Can someone please let me know if there is a way to have the doors auto-lock on my manual 2014 Corolla? I see lots of "how to's" on American sites - saying things like "hold lock button in on key after turning to ON", etc - but have not been able to get anything to work. My car is a ZRE-182R-AHFDKQ... apparently. Any assistance would be appreciated. -
Remote Touring LC 300 spares list
Hi Ray, I hope you get all the spares you can carry and have a great tour mate KAA -
Please help - back door handle on my Hiace broken!
Hi Merlin, I have kind of same problem. My van was stole I get it back fortunately, but now my problem is the door handle is broken and the door it's stuck, I can't open the door... Was you able to open the door ? -
6
Cabin Air Filter
Recently have encountered the same question for a 2002 Avalon. Pulled out the glovebox and didn't see anything that resembled the plastic cover for a cabin air filter. Anyone able to confirm if one exists? Thanks
