Damn... how wide is that?
Nothing wrong with some poke :lol:
Compare it to the 16" rim underneath it :P
I estimate it has -40 offset. Can I just use a 85mm spacer to make it similar to stock? Will it scrub?
14" :lol:
So it has finally arrive!!!
:clap: :clap: :clap:
-125 offset LOL
thats insane.
-125 offset LOL
thats insane.
nothing a set of flares cant fix.Which team is it from?
Red Bull Racing. For a 13" rim I'm surprised it fit over the stock brakes so well. Should have got the other 3 and modified a Formula Ford :lol:
Must be a poorly built wheel, look at all the wheel weights on the outside :lol:
Either that or they put a really crappy tire on it.
Could be used for running old tyres in practice/testing etc, or the wheel has copped a bashing (you'd be surprised how much they'd get hammered with going over ripple-strips etc at 200+km/h) and since they're so light, even the slightest buckle will throw the weights out.
Thats only 50g of lead, and directly opposite the big air valve. Of note is the complete difference to any air valve I have seen on a road rim before.
It also appears the rim is balaned at the front, and at the rear as it has lead at the back end of the rim. At that width the rim must be able to develop a wobble from either side ;)
The wheels tracking number is from the RB4, so 2008 with Webber and Coulthard.
  • 4 weeks later...
looks like a nice fit their SD ....... should give you that extra grip for the corners on the track ;)
      Tyre Sale Specials
      overheated engine
    5. 62
      Tyre Sale Specials
    9. 10
