Dylan's Sportivo
HiLift
Hey guys
Though it was about time I got some pics of my car up.
2005 corolla sportivo
-ENGINE-
Apexi Power FC + SD Harness
Custom Exhaust Specialists Cold Air Intake
Custom Exhaust Specialists Ported Headers
Custom Exhaust Specialists Cat Back System
Piper Stage 3 Cams
MWR Valve Springs
MWR Valves
Ported and Polished Head by HeadSense
Energy Susp Engine Mount Inserts
-DRIVETRAIN-
NPC HD Clutch with TRD Pressure Plate
Extreme chromolly flywheel
6th Gear Set 0.715:1
ARP Flywheel Bolt Set
Speed Source Clutch Push Rod
Speed Source Stainless Clutch Line
-HANDLING-
Pedders Sports Ryder eXtreme XA Adjustable Coil Overs
TWM Quick Shifter
Cussco Front Strut Bar
C-One Rear Tower Bar
Whiteline Rear Sway Bar
Toyo Proex R1R 205 R16
-STYLE-
Rolled Guards
Aftermarket Tail lights
Autometer Air/fuel Gauge
Red Console Light Conversion
Headlights Surround Painted Black
8000k HID Headlights
8000k HID Fog Lights
Stubby Antenna
Gizmo Shift Light
Eclipse Cd Player
Eclipse 6.5" Splits (front)
Eclipse 6" (rear)
Alpine Type R 12" Sub
Alpine 2x150w (front)
Alpine 1x600w (sub)
Edited by HiLift
Good work Dylan ..
Is the more to come ?(looks like you have everything i would like in my car mentioned here).. I know the CES CAI is inline but what else ??
IMO the Stock Stivo wheels still look so good on the car.I know i will keep mine till i get a good deal on Light wheels..
A SD's PFC harness next followed by another tune. might go to PIT's this time.
Then want to get the engine bay looking pretty.
after that ill have to decide on some wheels. not sure there are so many nice one's but all the ones I want are $$$$ so hopefully some pop up for sale.
Ive got newer photos to upload but it says ive used my global quota?
Dylan just use a 3rd part link to host the photos . photobucket etc ..
I had the same prob with my uploads .
Go to Options >Settings > Manage Attachments and see the photos you have uploaded and the size as well .
I had to reduce the size of some of my photos by 60% to fit a few more..
Here are some photos I took yesterday.
New ride height with the pedders coil overs. getting the guards rolled on Thursday hopefully this stop it from scrubbing Id like to go another 1/2 lower all round.
Edited by HiLift
nice sportivo and impressive mod list. whats the power output on this beast? around 140kw or more?
Edited by hAmZ
what are the pedders coils like? would you recomend them for daily duties?
love your ride man keep up the good work.
To be honest ive only done 100km on them but so far so good they can ride really nice. i think ive gone a little low im getting the guards rolled tomorrow so hopefully that fixes the scrubbing issues if not ill have to come up a bit
Very similar build to what I want to do :spiteful:
Tell me how are the R1Rs? I've been wanting R1Rs now for a while just waiting for my T1Rs to cark it.
Yeh they are very soft I don't think they'll last very long but so much grip hey. My main reason for choosing them was the look of the tread pattern.
Looks great. Got a better pic of those rear lights? and where did you get them?
I've been wanting to get some better looking lights for a while, haven't really been able to find any.
EBay cost like 150 for the pair.
HAHAHA i wish. Here is the latest dyno printout
shouldnt you be expecting a lot more? you could reach 119kw with just i/h/e i believe? how much gain did you make from stock?
Edited by hAmZ
every Dyno varies in readings im sure the drivability of the car is quite significantly different to a stock one!
To be honest drivability is shocking. maybe its just coz i need SD's harness but idle is really rough and stalls a fair bit and need heaps high revs to take off and really jerky at certain rev's. will be getting re tuned asap see if that makes a difference.
i know every dyno varies but that figure is weak!
drivability shouldnt be that bad! did 999 automotive tune it? i wouldnt let them near my car.
maybe after a retune with someone reputable should be sweet?
999 tuned it. Is that a bad thing? Call matt at pits and will get him to tune it from scratch if need be just got to get this clutch replaced
Looking to replace the clutch in the next few weeks who can recommend a flywheel for me?
MWR ultralight chromoly flywheel ;)
got the new clutch and flywheel in yesterday :) was hoping it would fix the constant crunch into 3rd. but looks like its the syncro. does this sound right? got quoted $600 to fix or $1200 for full rebuild? thoughts anyone??
      Toyota Landcruiser problems
    4. 7
      selling car
      Fuel Filter - Change or not
      2013 cruiser gxl ute
    7. 2
    8. 2
    9. 1
