My zre-154 0-100 video sharing
ben yip
2010 Corolla 1.8
Not a good start for 0-100, but some fun, time is around 8.8-9.2.
I can push harder, but find it pointless. I saw people push over the rev limit or start up with high rev to get the time down, but that's not the important part of this video
My start is very bad, i dun hold the clutch good coze I have been holding my mobile as well, otherwise, 8.5 second should not be problem. I have been scared of police as well although that road can do 80 maximum
Estimated output is 115kw at the crank compared to a stock car.. for 115kw and 1260kg, 8.5 is really a decent time
Note, the gear ratio for 1st gear and 2nd gear are really short..
1st gear ends at 40+, and 2nd ends at 80+
Modifications
Injen CAI,Catback, WeaponR header, NST pulley
1/4 tank of fuel, spare wheel off, and I weight 63kg
(starts at 20 second)
Video 2
Edited by ben yip
why is your corolla a zre154 when my mums facelift says zre152 on the plaque? is yours an import?
After 2009/11, All hatchback corolla has a styling update, it is called zre-154..
I am sure you saw heaps on the street...
May be I was wrong, I dun know
Edited by ben yip
Correct me if I'm wrong but i believe the 154 is the 4wd version, and the 152 is the 2wd version, which still makes our ZRE's the 152.
Yep im pretty sure that correct. 154's are 4WD.
Ben, your car does seem to rev rather quickly between 4-6k.. if i can get out tonight, ill give it a go for comparison.
For the rev, don't be fooled by the quick spin of 4-6k, they have changed gear ratio in 2009. Please refer to this post, Can you please confirm your max speed 1st and 2nd gear
http://au.toyotaownersclub.com/forums/index.php?showtopic=23465
The max speed for other cars for 1st gear are normally 60, mine is 40
Also, http://au.toyotaownersclub.com/forums/index.php?showtopic=29213
Q) What is the difference between ’07-’08 ZREs with ‘09 ZREs?
A) Both are pre-facelift ZREs. Differences are:
i) Gear ratios
Edited by ben yip
Just did a quick run, too many cars even on the quiet roads. Estimated times are around the 9.5-10 seconds. Half tank, fat me (125kg) and spare in.
Hope u can do it again next time see if you can capture a video for us, when your tank is close to empty. I want to see your 4k to 6k spinning speed
When my car is full tank, it lost half a second, so, my guess is for every 40kg, you lose around half a second..
When my car has another passenger, especially a male, the car is very very sluggish...
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
