The Official TOCAU ZRE Corolla FAQ
Bill is going to sticky/pin this.
Since ZREs are becoming more common, I thought I should make a 'ZRE FAQ' like the "ZZE FAQ" that currently exists. smile.gif
So like the "ZZE FAQ" thread (props to Evan), this FAQ will be constantly expanding as time goes on. If there is a question here that is not answered, try doing a search first before posting another thread. If you think there is something that I should add, don't hesitate to PM me (this will help reduce chatter in the thread). Hope this is useful for future questions.
Please check part numbers with manufacturer before placing any orders, as I WON'T be held responsible!
Q) What is the difference between a Pre-Facelift ZRE and a Facelift ZRE Corolla?
A) Simply External differences.
The Pre-Facelift ZRE (below) - 2007 - late 2009
The Facelift ZRE has a 'sharper' front (different grill, headlights & foglights) and different rear (different taillight, different shape bummer & with reflectors). In terms of interior, facelift has a slightly different steering wheel shape, different headunit and different looking handbrake.
Facelift ZRE (below) - late 2009 - current
Q) What is the difference between '07-'08 ZREs with '09 ZREs?
A) Both are pre-facelift ZREs. Differences are:
i) Gear ratios (slightly different and '09 ZRE has longer throw).
ii) '07-'08 ZREs have metal-type oil filters whereas '09 ZREs have a paper filter type.
iii) '07-'08 Levin ZRs have keyless entry sensors only on the driver's door, whereas '09 ZRs have it on front passenger side as well.
iv) '09 ZREs and up have VSC.
1. TRD Parts
For all your JDM TRD goodies, look here!
2. Wheels
The stock wheel sizes for the ZRE are:
i) Ascent: 15x6 steel with 195/65R15 91H tires
ii) Ascent Sport, Conquest, Levin SX/ZR & Ultima: 16x6.5 +45 alloy with 205/55R16 91V tires
Stud pattern: All grades - 5x114.3
Wheel nut thread: M12 x P1.5
Want to buy wheels? Check first using Wheel Offset Calculator & Tire Size Calculator.
Generally, people have gone 17"/18" by 7-8" wide rims with +35 to +40 offset. Best to search or ask/PM someone first before buying! smile.gif
3. Air Intake Mods
Before buying any intake mods, please read this thread!. There have been some "Check Engine Light" (CEL) problems that initially came up; however, these seem to have somewhat disappeared. Please read it before making any decisions.
Also, it has been debated here whether the pod needs covering or not. Make your own decision.
3.1 Blitz Intake System
Details here. 42155
3.2 CES Racing Custom Cold Air Intake
Need to contact CES Racing; BG Pete has got one made up for him.
3.3 Injen Cold Air Intake
SP2079 (Polished) or SP2079BLK (Black piping), Toyota Corolla 2009, 1.8L 4 cyl
Check threads 1, 2, 3.
3.4 K&N Universal Closed Air Intake Systems
Not 100% sure if will fit but may be an alternative. Click here.
3.5 Satisfaction/Simota Intake Systems
Check here and here.
3.6 Weapon-R Secret Weapon Intake
Although it is for the Corolla S (sedan) from the US (like Injen), it will fit our aussie ZREs. Looks more like a SRI. Click here.
3.6 DIY Cold Air Intake
Alternatively, you can make your own cold air intake (check this thread) or similarly, you can make your own SRI.
4. Suspension:
Q) Is the suspension for the ZRE hatch and ZRE sedan the same? Is the Facelift ZRE suspension the same as the Pre-facelift ZRE?
A) Yes, the chassis for the ZRE hatch and ZRE sedan, similarly for the facelift ZRE, are the same.
Part numbers for various manufacturers are given, they are in order of front springs and rear springs respectively, unless stated.
4.1 BC Racing Coilovers
BC Racing V1 Series Coilovers, see here.
BC Racing BR Series Coilovers, see here and here.
4.2 C-One Suspension Parts
C-One Front Strut (discontinued)
C-One Front Sway (discontinued)
4.3 Cusco Suspension Parts:
Cusco Front Strut - 942 540 A
Cusco Front Underbody Brace - 942 475 A
Cusco Front Sway - 925 311 A30
Cusco Rear Sway (16mm) - 942 311 B16
4.4 Eibach Springs – Pro-kit springs, Toyota Auris (E15) -30mm front, -35mm rear. Part number E10-82-024-05-22 (10755, 100286861)
Click here and here for photos.
4.5 Greddy Suspension Parts
Greddy Strut Tower Bar - Part Number: 14013040
4.6 K-Mac Suspension Parts
See here.
4.7 King Springs Lows (~35mm drop) – KTFL119, KTRL120
King Springs Standard – KTRS120 (rears only)
You can also reset your rears if you want your car sitting more level with lows. Some threads about resetting rears.
reset rears link 1
reset rears link 2
4.8 Lovell Springs Low (~35mm drop) – TFL-131, TRL-132
Lovell Springs Super Low – TFL-131SL, TRL-132SL
4.9 Pedders Suspension Parts:
Springs Low (Sports Ryder Coil Spring) – 2976 2976, 2977 2977
eXtreme XA Coilovers – Part Number: 160069
Front Camber Kit: 81290 81290
Flexible extension 125mm: 191001
Flexible extension 250mm: 191002
See juvenlle, shin0bi or dutchie.
4.10 RSR Best-i/Black Coilovers
4.11 Silver's NEOMAX Suspension Parts (F:6kg, R:5kg)
Silver's NEOMAX Coilovers - Part Number: NT127
4.12 Tanabe DF/NF/GF Coilovers
Look here (JE-55-EA) and here (Kev0).
4.13 Teins Type Flex Coilovers
See here.
4.14 TRD Suspension Parts:
TRD Springs (~25-30mm drop) – MS250-12002 (48130-ZE500)
TRD Front Sway - MS270-12002 (48800-ZE500)
Threads about suspension that may be useful:
09 ZRE sway bar combo
ZRE front strut braces
BC Racing Coilover Suspension Kit
5. Brakes
5.1 DBA
Standard Rotors:
- Standard fronts, DBA2742
- Standard rears, DBA2743
Slotted Rotors:
- Slotted front left, DBA2742SL
- Slotted front right, DBA2742SR
- Slotted rear left, DBA2743SL
- Slotted rear right, DBA2743SR
Cross Drilled Rotors:
- Cross Drilled fronts, DBA2742X
- Cross Drilled rears, DBA2743X
5.2 RDA
Slotted rotors, RDA7789S - $240/pair
6. Exhaust / Headers
ZRE Exhaust results
Exhaust, where do I start?
2ZR-FE Performance Headers
6.1 C-One Axle Backs (discontinued!)
Oval:
(pic)http://www.c-one.co...._auris_muff.jpg
Note the drive 2WD 1・ZRE152H NZE151H
●パイプ径60φ ● 60φ pipe diameter
●楕円メインマフラー The main oval muffler ●
●オーバルカールテール(80×120φ) Obarukaruteru ● (80 × 120φ)
●揺れ防止追加ステー、ラバーリング付属 Additional anti-sway state ●, rubber ring included
●M/T車取付可 ● M / T car can be mounted
●近接排気騒音:88dB Exhaust noise near ●: 88dB
Round:
(pic)http://www.c-one.co....auris_muff2.jpg
ZRE152H・NZE151Hの2WD車注1 Note the drive 2WD 1・ZRE152H NZE151H
●砲弾型メインマフラー ● Main muffler shell type
●スラッシュカールテール100φ ● 100φ Surasshukaruteru
●近接排気騒音:90dB Exhaust noise near ●: 90dB
6.2 TRD High Response Muffler Ver.S
Click here. MS153-12009
6.3 Universal mufflers such as Xforce Twinloop or Magnaflow etc
7. Throttle Controllers
7.1 ARK ATCC Throttle Controller
Look here.
7.2 Blitz Throttle Controller
TRC001P-BG1 - 14713
7.3 E-Drive Throttle Controller
Look here.
8. Forced Induction?
Turbo ZRE152 Sedan
ZRE Turbo Update
ZRE Injectors - & Turbo update
9. External Mods
There are heaps of mods for those who want their ZRE to look very nice! There are parts such as front garnishes, front lips, rear skirts, rear spoilers, OEM accessories..etc
9.1 TRD Parts here.
9.2 Genuine Toyota Slim Weathershields
Can either get it from Castle Hill Toyota ($275), JZSInternational (genuine Toyota $200US) or ebay (genuine can be questioned).
9.3 Modellista Parts
9.4 Other External Parts
Euro Auris/ ZRE rear skirt
10. Removing Front Bar/Bumper
11. DIY Colour-Code Front Lip
Check here.
This FAQ thread is ongoing and I'll complete every time I have time to do so (final semester of uni :spiteful:). I might not have had time to cover some parts but feel free to PM me about any parts I have not covered anyway, I might have not thought about some things.
Hope this is useful for future reference!
Once again, if you can't find what you are looking for (either by searching or looking at this FAQ), please PM me.
Some thanks goes to Jesse (JE-55-EA), Pete (Dutchie), John (juvenlle), Vinh (le.vinh.zr), Peter (pezzie), Will (Ascendant Rice), other John (jtron85), Ben (benyip) and Jason (jps137) for the help! biggrin.gif
Peter.
  • 4 weeks later...
All toyota part numbers below
http://www.japan-parts.eu/
Full facelift ZRE 154 parts map as below, I don't know what language is that, but there are japanese in the picture (I can read japanese)
http://au.toyotaowne...showtopic=29681
Below is the English version of ZRE-151 parts
http://www.toyodiy.c...L-GEMNKC_1.html
The part number might not be the same in Australia, but these maps can save so many people
For brake option, DBA has slotted disc for $125 pair, sold in pedders
QFM has A1RM and HPX brake pad for our cars, I have A1RM for $165 pair, please contact GSL rally sport for details, need to wait 4 weeks for custom made
They also get Remsa brake pad which cost $110 pair for the front
Pedders also got camber bolt at the front, maximum -2.5 can be achieved. No camber at the rear, but the rear camber is -1.25 if you lower your car
If you plan to chip your car, unichip is an option for $1.5K+, check my thread for details. Not recommend unless you are really serious
If you want spolier, mudflag, skirt, fog light, please see
http://au.toyotaowne...ight-skirt-etc/
Edited by ben yip
Full ZRE 154 parts map as blow, I don't know what language is that, but there are japanese in the picture (I can read japanese)
http://au.toyotaownersclub.com/forums/index.php?showtopic=29681
Why do the face lifts have diffent code to the pre? i thought the face lifts were also zre152 ><!!!
just wanted to note that the stud/bolt pattern hasnt been listed :) i have been trying to confirm that the zre152 is 5x114.3
The ZRE is 5x114.3. FAQ has been updated with that detail now.
thanks heaps champ
thanks heaps champ
Sorry about that, forgot to add that in. This FAQ needs more info, but I'll update it after exams. :)
Thanks DJ. :P
oh, also quickly could just ask, as me and the gf are looking at some wheels, looking at around 17x7.5 what would be a good offset? im guessing between +40 to +45? would +38 be ok?
17x7.5 with +38 should be fine. +45 might be too much for 7.5". Wheel Offset Calculator.
If you want to find the right tyre to fit, try Tire Size Calculator.
Peter.
Is there meant to be a difference at all between the wheel specs for the hatchback and sedan?
I emailed the Toyota people and got a reply saying the sedan was 5x100. I didn't actually think it'd be different. =S
Watch this post, I'll confirm but I believe it should be the same, 5x114.3 stud pattern.
Peter.
Peter.
Forgot to mention I got one of the current Corolla's, not the earlier model. If that helps. =S
Peter.
Haven't confirmed yet, but it is 5x114.3. Reason being, one of the guys on here has a sedan (HungryforaRolla) has wheels given to him by a friend who has a hatch. Any Corolla manufactured after 2007 (preface ZRE) to current (facelift ZRE) have the same ZRE152 chassis and same 5x114.3 stud pattern.
  • 2 months later...
Wheels & exhaust section updated! Thanks Dutchie. :)
Will have to add and clean up the suspension section.
If you have more information that is missing or should be on here, PM me! :)
Peter.
  • 5 months later...
Air Intake section updated as well as some misc items.
Still to clean up the suspension section. This FAQ is a continuous work in progress! :)
Peter.
  • 3 months later...
Hey guys,
I have a Toyota corolla ascent 2008. I need to flush the brake fluid. I bought genuine Toyota brake fluid and I'm thinking of doing it by myself or give to a mechanic to do it for me.
If I do it myself I need to know the best way to do it with tools and steps and whether there is a garage that I can hire for an hour or two to do it.
If I'm to give it to a mechanic I need to know how much it will cost given that I will provide the brake fluid. Also if you know a good mechanic around Sydney cbd or meadowbank
Cheers,
Ramses
DBA slotted rotors info added, thanks Jason! :)
This FAQ is a continuous work in progress! If you have more information that is missing or that should be on here, PM me! :) (I'm sure I'm missing stuff on facelift ZREs :P)
This thread is AWESOME!!! :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
Cheers brother!
Hey guys,
Cheers,
Ramses
Hey Ramses, I don't know too much about flushing the brake fluid (have never done it) but I have heard it's relatively easy and I would assume it's similar to flushing other cars. Doing a quick search, looks like your question has already been answered. :)
DBA standard, slotted and cross drilled rotors added thanks to Jason! Silver's NEOMAX Coilovers (F:6kg, R:5kg) added:thanks to Julian! Thanks guys! toast:
  • 6 months later...
Just a question about suspension,
Would lovell sports front and superlow rear be fine on stock shocks? Thought this would be a place to ask a, I'd assume, frequently asked question :P
Thanks in advaned
Thanks in advaned
Hey mate. It would be fine on stock shocks but be mindful that they will wear out a little faster. Once the stock shocks wear out, it is recommended/ideal you get aftermarket shocks to suit the springs. Hope that helps.
Thanks in advaned
Cheers mate! just needed some words from someone who knows what they are talking about xD
    2. 4
    3. 0
      Has anyone found 200 Series Rear Screen Delete Cover in AUS
    4. 11
    5. 1
      2007 - floor mats
    6. 1
    7. 0
      2002 Hilux Engine Replacement
    8. 3
      Engine conversion
      Po299
    10. 0
      Boot Dimensions?
