Hi guys,
I'm having problem to fit the single din fascia kit into the center dash panel hole.
The fascia kit i got is slightly larger than the hole, I tried to use a little bit of force to push it in but still no luck.
Do you guys realised that the US and UK version ZZE, the center dash panel hole is slightly larger than Australia?
I noticed that all the single din fascia kit available to ZZE in Australia are designed from US and it won't fit the Australia version.
I have searched the entire forum & www and I still can't find a solution.
Have anyone come across this problem?
Where do you get your single din fascia kit?
I got one from Autobarn. I believe that I got a generic toyota double din kit. I know that Hilux's from the similar year as my 2005 sportivo use the same cd player
Do you mind take a close up picture of your head unit to show me how your fascia kit looks like is? Thanks.
Go to strathfield car aadio they have one i use it,its perfect.
Posted (edited)
hey mate.
this is how my car came stock.
it was a double din, with a little plastic panel as it only had a single din HU in
anyway, thought these images may be of a bit of help.
i know Ryda makes a double din for the ZZE
So I'd be thinking get that and just put the little plastic panel there to cover up the hole left by not having a double din HU
oh and the second image is the panel which I have removed from my car,
double din dvd player in now with a playstation 2 hooked up :D
Edited by RollaRollin
Here is my 2nd fascia kit I bought from SparesPlanet.com.au.
They imported the fascia kit from America.
Again this also won't fit the hole, I took the measurement already.
I do not want to open the package, once I opened I can't return to the seller.
post-22906-0-64093700-1305799073_thumb.j
post-22906-0-89708000-1305799087_thumb.j
Thanks for posting your HU.
I can see you used the existing brackets to hold your single din HU, right?
With the right fascia kit, it should not need to cover up any holes left behind.
Ideally, I would like somethings to fully cover the hole like the one I bought from ebay.
Unfortunately, the kit is only designed for America & UK's Corolla.
hey mate.
  • 4 weeks later...
      2006 Aurion 222000kms
    2. 0
    3. 1
      Tyre Sale Specials
    4. 0
      overheated engine
    5. 1
    6. 62
    7. 1
    8. 1
    9. 1
      Tyre Sale Specials
    10. 10
      Android auto
