[NSW] SYDNEY MONTHLY MEET
9164708369_db67286ab0_c.jpgjust a photo i was mucking around with on my phone :P
good to meet some new peeps but the weather was kinda a let down <_<
Edited by Kreezy*
Will have to double-check the dates, but I'm keen. Wollombi run is always good, and I'm much closer to home at the end of it too.
Does the tavern allow under 18?
Not allowed in the pub, but can order food
The pub doesn't help me eitherm:p being on p's and all
They still serve softdrinks....if all else fails, someone can you drink
Just FYI, the bistro section is separate from the bar. And there are plenty of tables etc outside where you can sit, eat and enjoy the sun.
Also, depending on the pub, under 18s can be in the bar section as long as they are accompanied by a responsible adult - small bar licenses don't normally allow this though (and Wollombi Tavern isn't that huge).
      2013 cruiser gxl ute
      help with clutch
    6. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    9. 2
    10. 1
