4ABHGE's Red Lunch Box - Goners!
4ABHGE
You blokes are getting closer. :P
Jo you caught me out!! its a ficticious bird from New Zealandland known as a doo doo... I photoshopped it for teh lulz
I am more of a flute fan. Nothing like someone that can handle a flute., Trumpets are for squares
Yeah well... flutes are for teh gheys!!
Lots of things to do before trackday, need to sort out rear fitment issues with 205's on, then do a skid, then go lower and wider with camber, and sort out some scrubbing issues... not because herrafrush, but because racecar! ;)
Hahahahaha!!
So sad, had to remove the little red angry bird because it was losing its beak :( it will come out for special occasions though :D
Wheels fit with minimal rubbing! Its only rubbing on the rear bumper as its the lowest i have ran these wheels. Its fine though. Really happy with how it worked out as I only raised the rear by 10mm which evens up the heights
I also added rear cambers :)
Bashed the inner guard out to make room and ended up cracking the bog i used to cover the rust for the RWC many moons ago. Ill fix it up nice and proper along with a few other places of rust in the car, looks a bit ugly but FUNCTION>FORM
Found out my guards had no solid outer skin. The outer guard was made of bog and was all that was holding my guards together. So I rage quit the guard and made a new more solid item to go in its place. Plus now i has more room for the 205's!! :D
Havent taken a pic of the end product, but lets just say my car is multi-coloured for now... :P
I cant believe Ive had this for a year and a half now, shes come a long way since then :)
Here's how I bought it.
Edited by 4ABHGE
      Front Cameras
    3. 51
    4. 51
      1kzte throttle body
      Aftermarket parking sensor
    8. 4
      Head Unit with Apple CarPlay
    9. 8
    10. 1
